TRANNY/CLUTCH Problem....NEED Help!!
Old Dec 7, 2003 | 08:23 AM
Synergy001's Avatar
Default TRANNY/CLUTCH Problem....NEED Help!!
I have a weird tranny/clutch problem that I've never had before. It all happened after I accidently mis-shifted into fourth. Well anyways...when i release the clutch AFTER putting it in gear while the car is moving something grinds when it engages. Usually if the tranny is grinding it would grind going into gear and not when releasing the clutch. It feels normal in neutral when I press the clutch and release it. Could it be the clutch or the tranny? NEED HELP!! TIA!!
Old Dec 7, 2003 | 08:48 AM
Kendall's Avatar
It sounds most likely to be in the tranny. I don't know what it is but you probably need to take it to a tranny specialist. The good things is that if you have a D series motor, you can pick up a good used tranny for almost nothing. And while you're at it you can go ahead an move to a stronger clutch.
Old Dec 7, 2003 | 09:42 AM
Synergy001's Avatar
Default Re: (dc231)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc231 &raquo;</TD></TR><TR><TD CLASS="quote">It sounds most likely to be in the tranny. I don't know what it is but you probably need to take it to a tranny specialist. The good things is that if you have a D series motor, you can pick up a good used tranny for almost nothing. And while you're at it you can go ahead an move to a stronger clutch.</TD></TR></TABLE>
luckily i have an extra tranny, clutchmasters flywheel and ACT extreme clutch on the side both with only 1k miles. tranny was rebuilt...lol...but yeah i just wanted to know what the problem was before i swap it out
bnasty84
Jul 28, 2008 10:02 PM
13link EG
Jul 30, 2005 08:53 PM
ogichida
May 11, 2005 10:59 AM
Synergy001
17
Dec 8, 2003 10:07 PM
