Bad Throttle body an b16a
Old Sep 26, 2005 | 06:46 PM
CiviCVuE's Avatar
Default Bad Throttle body an b16a
What are some signs that you might have a bad throttle body or your throttle body is going bad.
The reason I ask this is because my car idles bounces from 1000 to 1200 when the car is warmed up constantly. I can then put alittle pressure on the throttle lever to close it more and it will idle normal again evey time.
I have done vaccum leak checks cleaned my iacv and swapped it cleaned and screwed in the plastic part in the fitv and swapped it, swapped ecu's, adjusted the idle screw, checked and swapped throttle cables, replaced my throttle body gasket and still have this damn bouncing idle so any info or suggestion would help me thanks.
Old Sep 26, 2005 | 06:50 PM
dantastic's Avatar
Default Re: Bad Throttle body an b16a (ridindeep2001)
have you tried adjusting the stop on the throttle rotor? allowing to close more?
Old Sep 26, 2005 | 06:53 PM
CiviCVuE's Avatar
Default Re: Bad Throttle body an b16a (dantastic)
no i have not, i will try that though. thanks
Old Sep 26, 2005 | 07:03 PM
CiviCVuE's Avatar
bump
Old Sep 26, 2005 | 07:31 PM
chinese acrobat's Avatar
If there's no problem with the timing. Throttle rotor is my input too.
Old Sep 27, 2005 | 07:17 PM
CiviCVuE's Avatar
Default Re: (chinese acrobat)
I need to check my timing, but you think that could cause this bouncing idle.
phelpsj2
Nov 3, 2011 02:35 PM
95_red_dc
Sep 11, 2006 09:47 PM
Initial DA6
Aug 29, 2002 03:24 PM
luc_cairo
May 2, 2002 06:33 PM
ttboy
Feb 18, 2002 12:04 PM
