honing cylinders and aftermarker pistons and rods?
are you all sure this is ok do to. this is my plan. since my motor is messed after a summer of boosting, ill hone the stock sleeves and get new rods and low compression pistons. is there any point to getting aftermarket rods with stock sleeves? or should i just get new pistons and rings and keep stock rods? how much boost can i run safely with new 9:1 pistons and eagle h beam rods with the stock sleeves and head???
thanks
thanks
Do some research. No you don't need to upgrade the head. We don't know if you can run 18 psi, it depends how much power that turbo makes at 18 psi. I would trust stock sleeves to 500whp on a good tune though so, there you go.
i dont have replace anything in the head to make it stonger?
what kind of pistons and rods should i get?
do i need to pull the motor to replace these parts? i was reading that you can do it from the bottom with head off?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar »</TD></TR><TR><TD CLASS="quote">i dont have replace anything in the head to make it stonger?
do i need to pull the motor to replace these parts? i was reading that you can do it from the bottom with head off?</TD></TR></TABLE>
I thought I posted about stock sleeves and built internals on one of your threads?
But anyways I'm pretty sure you'll have to pull the motor. IMO it would be easier on the person rebuilding the motor. For you head, you could stay with the stock valvetrain if you wanted to. Not really necessary to replace anything unless it's broken, out of spec of if you wanna go with something better.
I believe people have been doing stock sleeves and upgraded internals for a long time. It's probably just in the last few years that people started pushing the stock sleeves to new HP levels. Or maybe it's just that people started noticing it more. If you decide to keep the stock sleeves you should be fine. Just get yourself a set of pistons, rods and ARP headstuds.
that will cost like just over a grand them. any name brands i should be looking for. i think im going to attempt rebuilding it myself so i will pull the motor this winter
Here are some suggestions and these are just my personal preference. There are other brand names out there, but these are the ones I would choose.
PISTONS:
CP
Wiseco
RODS:
Eagle
Manley
Pauter
Full-Race.com Turbo Tuff rods
BEARINGS:
OEM
ACL
MISC:
ARP headstuds
new OEM headgasket, OEM water and OEM oil pump (might as well)
PISTONS:
CP
Wiseco
RODS:
Eagle
Manley
Pauter
BEARINGS:
OEM
ACL
MISC:
ARP headstuds
That's what I did when I replaced my pistons/rods.
Capt. Jimbo McSubipants
Nov 22, 2005 03:50 PM
