SRS light with after market wheel
Old Sep 25, 2005 | 10:11 PM
Fugun's Avatar
Default SRS light with after market wheel
i tried a search, and there were many other things that popped up.. but not exactly what i was looking for
when i change my steeringwheel,does anyone know what i need to do to get that srs light to turn off? ! with out pulling the bulb out ?
Old Sep 25, 2005 | 10:21 PM
u2civic1's Avatar
Default Re: SRS light with after market wheel (Fugun)
MES=PAPERCLIP
Old Sep 25, 2005 | 10:22 PM
Kyles ej1's Avatar
Default Re: SRS light with after market wheel (u2civic1)
dude all you gotta do is remove the cluster and pull out the yellow clip and your good.....that simple, thats it
Old Sep 25, 2005 | 11:25 PM
hatchi's Avatar
Default Re: SRS light with after market wheel (Kyles ej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kyles ej1 &raquo;</TD></TR><TR><TD CLASS="quote">dude all you gotta do is remove the cluster and pull out the yellow clip and your good.....that simple, thats it </TD></TR></TABLE>
Or take out the bulb.
Old Sep 26, 2005 | 05:37 AM
monicle's Avatar
Old Sep 26, 2005 | 08:22 AM
Eglifestyle's Avatar
Default Re: SRS light with after market wheel (monicle)
i almost got the same problem wiht my civic 95 but the thing is the car was into a little collision i rebuilt it back up and since the old air bags popped out i replace both of them with new air bags and computer as well but the srs light still comes out and stays out....i dont if i need to reset the ECU bc the ECU still have the air bags as if the they were popped out still.....
Old Sep 26, 2005 | 08:26 AM
RedEK9's Avatar
Default Re: SRS light with after market wheel (Eglifestyle)
I think you need a new SRS Unit to get it all back to normal...
Old Sep 26, 2005 | 08:32 AM
JDM-97CX's Avatar
Default Re: SRS light with after market wheel (RedEK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedEK9 &raquo;</TD></TR><TR><TD CLASS="quote">I think you need a new SRS Unit to get it all back to normal... </TD></TR></TABLE>
I think it just needs to be cleared of codes.
Old Sep 27, 2005 | 07:34 AM
Fugun's Avatar
where do i get the connecter?!
Old Sep 27, 2005 | 07:43 AM
JDM-EJ1's Avatar
Default Re: SRS light with after market wheel (hatchi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi &raquo;</TD></TR><TR><TD CLASS="quote">
Or take out the bulb. </TD></TR></TABLE>
This sounds like the better idea.
Old Sep 27, 2005 | 02:34 PM
u2civic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fugun &raquo;</TD></TR><TR><TD CLASS="quote">where do i get the connecter?!</TD></TR></TABLE>
connecter is a paper clip
Old Sep 27, 2005 | 07:26 PM
C2daIzZle's Avatar
all it has to do is be cleared, theres a diy in the faqs section. i had mine cleared today @ the honda dealership, however my friend is a mechanic there so that is why i went there bc it was free.. i looked @ the tut thou it didn't look to incredibly tough thou.
Old Sep 28, 2005 | 11:11 AM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fugun &raquo;</TD></TR><TR><TD CLASS="quote">i tried a search, and there were many other things that popped up.. but not exactly what i was looking for
the easiest way to turn the light off is to unplug the yellow plug going into the back of your gauge cluster; it's even easier than pulling the bulb. you won't be able to reset the light without putting in a resistor.
Modified by civicdxtyper at 1:23 PM 9/28/2005
Old Sep 28, 2005 | 11:20 AM
monicle's Avatar
Default Re: SRS light with after market wheel (civicdxtyper)
considering the toipc is "SRS light with after market wheel " its an aftermarket wheel and you should do what I posted above. connect a 2amp fuse to the srs connector. then reset the srs light. its not that hard.
Old Sep 28, 2005 | 11:26 AM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle &raquo;</TD></TR><TR><TD CLASS="quote">considering the toipc is "SRS light with after market wheel " its an aftermarket wheel and you should do what I posted above. connect a 2amp fuse to the srs connector. then reset the srs light. its not that hard.</TD></TR></TABLE>
ya i'm still learning this whole 'reading' thing
Old Sep 28, 2005 | 06:33 PM
hatchi's Avatar
i'm going to try this idea.
Old Jul 20, 2006 | 12:14 PM
Ruffryde009's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by u2civic1 &raquo;</TD></TR><TR><TD CLASS="quote">
MES=PAPERCLIP</TD></TR></TABLE>
alrighty well up from the dead.... by doing this WILL IT completly get rid of the SRS light even if you have a steering wheel with no airbag or a bucket seat (for example)?
thanks
Old Jul 20, 2006 | 09:13 PM
Harryflores's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi &raquo;</TD></TR><TR><TD CLASS="quote"> take out the bulb. </TD></TR></TABLE>
Man! that makes you no better than a NooB...
Old Jul 20, 2006 | 09:45 PM
sniggler316's Avatar
Default Re: SRS light with after market wheel (EM2RidinClean)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM2RidinClean &raquo;</TD></TR><TR><TD CLASS="quote">
thanks</TD></TR></TABLE>
No, the light will just come back on because it senses you have no airbags. Unplug it from the back of guages is the simplest way.
Civic-Kids
Oct 2, 2009 03:08 PM
lsjon
Jun 17, 2009 02:11 PM
Slava.
10
Apr 29, 2006 07:33 PM
ososlow24
11
Nov 4, 2004 05:16 AM
CaRiXma
Apr 13, 2003 09:51 AM
