SRS light with after market wheel
i tried a search, and there were many other things that popped up.. but not exactly what i was looking for
when i change my steeringwheel,does anyone know what i need to do to get that srs light to turn off? ! with out pulling the bulb out ?
1 Post
Re: SRS light with after market wheel (Kyles ej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kyles ej1 »</TD></TR><TR><TD CLASS="quote">dude all you gotta do is remove the cluster and pull out the yellow clip and your good.....that simple, thats it </TD></TR></TABLE>
Or take out the bulb.
Re: SRS light with after market wheel (monicle)
i almost got the same problem wiht my civic 95 but the thing is the car was into a little collision i rebuilt it back up and since the old air bags popped out i replace both of them with new air bags and computer as well but the srs light still comes out and stays out....i dont if i need to reset the ECU bc the ECU still have the air bags as if the they were popped out still.....
1 Post
Re: SRS light with after market wheel (RedEK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedEK9 »</TD></TR><TR><TD CLASS="quote">I think you need a new SRS Unit to get it all back to normal... </TD></TR></TABLE>
I think it just needs to be cleared of codes.
Imperious: Mod of Valor
Re: SRS light with after market wheel (hatchi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi »</TD></TR><TR><TD CLASS="quote">
Or take out the bulb. </TD></TR></TABLE>
This sounds like the better idea.
Re: SRS light with after market wheel (Fugun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fugun »</TD></TR><TR><TD CLASS="quote">where do i get the connecter?!</TD></TR></TABLE>
connecter is a paper clip
all it has to do is be cleared, theres a diy in the faqs section. i had mine cleared today @ the honda dealership, however my friend is a mechanic there so that is why i went there bc it was free.. i looked @ the tut thou it didn't look to incredibly tough thou.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fugun »</TD></TR><TR><TD CLASS="quote">i tried a search, and there were many other things that popped up.. but not exactly what i was looking for
the easiest way to turn the light off is to unplug the yellow plug going into the back of your gauge cluster; it's even easier than pulling the bulb. you won't be able to reset the light without putting in a resistor.
Modified by civicdxtyper at 1:23 PM 9/28/2005
1 Post
Re: SRS light with after market wheel (civicdxtyper)
considering the toipc is "SRS light with after market wheel " its an aftermarket wheel and you should do what I posted above. connect a 2amp fuse to the srs connector. then reset the srs light. its not that hard.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle »</TD></TR><TR><TD CLASS="quote">considering the toipc is "SRS light with after market wheel " its an aftermarket wheel and you should do what I posted above. connect a 2amp fuse to the srs connector. then reset the srs light. its not that hard.</TD></TR></TABLE>
ya i'm still learning this whole 'reading' thing
1 Post
i'm going to try this idea.
Re: SRS light with after market wheel (u2civic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by u2civic1 »</TD></TR><TR><TD CLASS="quote">
MES=PAPERCLIP</TD></TR></TABLE>
alrighty well up from the dead.... by doing this WILL IT completly get rid of the SRS light even if you have a steering wheel with no airbag or a bucket seat (for example)?
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi »</TD></TR><TR><TD CLASS="quote"> take out the bulb. </TD></TR></TABLE>
Man! that makes you no better than a NooB...
Re: SRS light with after market wheel (EM2RidinClean)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM2RidinClean »</TD></TR><TR><TD CLASS="quote">
thanks</TD></TR></TABLE>
No, the light will just come back on because it senses you have no airbags. Unplug it from the back of guages is the simplest way.
Civic-Kids
10-02-2009 03:08 PM
CaRiXma
04-13-2003 09:51 AM
