Wierd TPS ??
Old Mar 1, 2002 | 06:11 PM
Wes d's Avatar
Default Wierd TPS ??
I am trying to adjust my tps but cant seem to hit the 4.5 at WOT
I am only able to hit about 3.5 max. Throttle closed I am reading .46 volts so that is good. I am wondering if this is ok or am I loosing power wothout hitting the target 4.5 volts wide open. Could I possibly have a bad tps?
Old Mar 1, 2002 | 06:22 PM
BreakStuff's Avatar
New User
Default Re: Wierd TPS ?? (Wes d)
I wouldnt worry about it too much as long as you dont notice any "dead" spots between idle and WOT.. take into consideration that residual heat from the motor and intake will also increase resistance throwing the tps values off...
Old Mar 1, 2002 | 07:19 PM
Wes d's Avatar
Default Re: Wierd TPS ?? (BreakStuff)
cool, thanks. Maybe I'll try again when she cools off.
Old Mar 1, 2002 | 07:36 PM
G's Avatar
G
You may want to check all ecu grounds.....
Kid-jdm-teggy
Jan 18, 2014 07:20 AM
Throwback23
May 4, 2010 09:33 PM
JDMCivicHatch93
Jun 17, 2003 04:18 AM
iwouldHITit
Mar 9, 2003 08:33 PM
soHybridized
Mar 13, 2002 10:22 AM
