Frustrated with Short Shifter Install.
Old Sep 25, 2005 | 09:13 AM
Mushvroom's Avatar
Default Frustrated with Short Shifter Install.
Well, I have loosen all the nuts and bolts that holds the rod which holds the shifter. I am unable to take the WHOLE thing out. I unhooked some of the exhaust hangers, except one( on the muffler ). Still unable to. I guess my last resort is to loosen the nuts that hold the header and the exhaust together, so i can take it out. But is there another way? Thanx.
Old Sep 25, 2005 | 09:14 AM
Vintech's Avatar
Default Re: Frustrated with Short Shifter Install. (Mushvroom)
Did you remove the pin?,
i thought you wanted to remove the whole linkage.
I just woke up
Modified by Vintech at 12:35 PM 9/25/2005
Old Sep 25, 2005 | 09:28 AM
veggiemaster's Avatar
it shouldnt be that hard. there are seriously like 2 nuts and 1 bolt you have to take out under the car. thats pretty much it.
check this out...
http://www.team-integra.net/se...D=581
yes, i realize its for an integra, but its basically the same concept.
Old Sep 25, 2005 | 09:32 AM
Sleepy_Red_hatch's Avatar
Default Re: Frustrated with Short Shifter Install. (veggiemaster)
https://honda-tech.com/zerothread?id=1007935
i have it bookmarked, its a GREAT visual step by step
Old Sep 25, 2005 | 09:35 AM
Mushvroom's Avatar
Thanx ya'll. I kinda skimmed over those. I have the nuts loose, I just CAN'T get the rod shifting rod out. I am probably gonna be loosening the exhuast and header so I can take it out. It's just too hot right now.
Old Sep 25, 2005 | 09:53 AM
ImNaked06's Avatar
I remember mine being a bitch as well. Did you take off the center console and unscrew those two bolts by the shifter? You have to pull some carpet away but they're there. Just my .02
Old Sep 25, 2005 | 10:46 AM
Lucky 7's Avatar
Default Re: (ImNaked06)
doesn't the short shifter mess up your tranny?
Old Sep 25, 2005 | 10:59 AM
fwdtamiya's Avatar
Default Re: (Lucky 7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lucky 7 &raquo;</TD></TR><TR><TD CLASS="quote">doesn't the short shifter mess up your tranny?</TD></TR></TABLE>
They have the potential to
Old Sep 25, 2005 | 06:08 PM
Mushvroom's Avatar
ok thanx
Old Sep 25, 2005 | 06:36 PM
Ricey McRicerton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lucky 7 &raquo;</TD></TR><TR><TD CLASS="quote">doesn't the short shifter mess up your tranny?</TD></TR></TABLE>No. Drivers tear up trannies, not shifters.
Old Sep 27, 2005 | 08:42 AM
Mushvroom's Avatar
now i got it out YES....but another thing.
The new short shifter "hole" below the ball..has a bigger hole than the other aftermarket hole..do I still use the same sleeve? thanx.
Old Sep 27, 2005 | 08:43 AM
Mushvroom's Avatar
and is there an easier way to take out the sleeve?
JerkzEm1
May 16, 2005 06:34 PM
Scantron
Mar 14, 2005 02:50 PM
slammedcivic22
Sep 14, 2004 04:06 AM
Integrity 19
Sep 6, 2004 07:04 AM
erikjohn19
Sep 28, 2001 10:48 AM
