crx tie rod help
Old Sep 24, 2005 | 08:10 PM
zccr-xsi's Avatar
Default crx tie rod help
my tie rod crown bolt wont come lose it just spins the whole ball joint.any ideals on how to break it lose.i have tried losen it with a load,i have tried holding the tie rod still didnt lossen up just spins.someone please give me a hand here
Old Sep 24, 2005 | 08:25 PM
Tyson's Avatar
Default Re: crx tie rod help (vteckillenzc)
borrow/rent an electric impact wrench. itll come out easily then.
then buy an 10x1.25 tap and die set and chase the threads on the castle nut and balljoint to save your tie rod and castle nut. although i recommend just buying a new castle nut.
Old Sep 24, 2005 | 08:29 PM
zccr-xsi's Avatar
tried it it was a bad *** air impact,the ball jonit did nuttin but spin really fast.
Old Sep 25, 2005 | 01:20 AM
Tyson's Avatar
Default Re: (vteckillenzc)
well, if youre really desparate, you can try two things.
cut a slot at the tip at the bottom of the threads, and then use a screwdriver to hold it in place while you wrench it out.
if that dont work, then just saw it off....
Old Sep 25, 2005 | 05:49 AM
SVOboy's Avatar
What happened with my tie rod end was that the bottom part with the castle nut actually seperated from the top part. So I ending up taking off the top part and then clamping the bottom and unscrewing.
https://honda-tech.com/zerothread?id=1368101
Old Sep 25, 2005 | 06:24 AM
zccr-xsi's Avatar
ight guys i got it off i hit the balljoint seperator to hold to ball joint and it held it enough so i can spin the nutt lose.thanks for the replys and suggestions.
BIGef
20
May 5, 2013 03:38 PM
LOC714
Nov 14, 2009 11:30 PM
MenaceDee
10
Mar 7, 2008 07:23 PM
yoffer
Apr 29, 2007 08:33 PM
teler86
Jan 25, 2006 04:47 PM
