Cant get tie fod on??????!!!HELP ME!!
Old 04-29-2007, 12:16 PM
Banned
yoffer's Avatar
Default Cant get tie rod on??????!!!HELP ME!!
I cant get the tie rod nut on the tie rod. Everytime i try to wrench it the tie rod just goes around witht he nut. There is nothing for me to hold it with so that i can tighten the nut? What do i do?
Modified by yoffer at 1:34 PM 4/29/2007
Old 04-29-2007, 12:36 PM
Banned
yoffer's Avatar
Bump....have been trying to fix this for 3 hours now.
Old 04-29-2007, 12:59 PM
Bejita's Avatar
You hold the tierod with one wrench....Tighten the nut with another.
Old 04-29-2007, 01:14 PM
Banned
yoffer's Avatar
No its the outer tie rod. The one that connects to the hub assembly.
Old 04-29-2007, 01:25 PM
h2point2's Avatar
you need air tools, its the only way i have found to get it up and somewhat tight, then you can tighten with a wrench
Old 04-29-2007, 08:33 PM
SNYPR2's Avatar
Default Re: (h2point2)
try a big pair of channel locks and squeeze the outer tie rod and the knuckle together and try to tighten it. also you can Pry the tie rod down with a pry bar and try to tighten it. when you squeeze the tie-rod into the tapered hole it'll tighten up and won't spin and you'll be able to tighten the castle nut on. good luck man
Milab21
Suspension & Brakes
12-10-2009 11:22 AM
96 GSR-T
11-22-2008 05:58 PM
MenaceDee
10
03-07-2008 07:23 PM
msinsky14
50
04-21-2007 03:50 AM
PINKS
04-19-2006 08:16 AM
Quick Reply: Cant get tie fod on??????!!!HELP ME!!
