Brake problem on my 92 civic hatch
Old Sep 24, 2005 | 06:43 AM
GdmLaz's Avatar
Default Brake problem on my 92 civic hatch
k well the problem is pretty easy to describe the car basically is braking all the time not brakin as much as the car won't move when u accelerate but the car is being braked enough that you won't be able 2 push it and when u in neutral the car brakes pretty quick what can i do 2 fix this and im smellin my brake pads gettin burned up the ***
Old Sep 24, 2005 | 06:56 AM
Bcuz's Avatar
Default Re: Brake problem on my 92 civic hatch (Slammed92hbonN20)
I think your saying, your brakes are always on???? If thats the case you may have a stuck caliper. Or your pads may be the wrong ones for your vehicle. Sorry can't understand your problem.
Old Sep 24, 2005 | 10:27 AM
GdmLaz's Avatar
yes thats exactly my problem my 2 front brakes are stuck on
Old Sep 24, 2005 | 10:42 AM
GdmLaz's Avatar
up top need help
Old Sep 24, 2005 | 08:27 PM
Bcuz's Avatar
Default Re: (Slammed92hbonN20)
Read what I left in my response, it will help as a starting point if not a fix.
Old Sep 24, 2005 | 09:44 PM
Andres-eh2's Avatar
Seems like the calipers are seized to me also
Old Sep 24, 2005 | 09:53 PM
allmotorEG-SI's Avatar
take apart the front brakes. Its quick and easy to do. try and press the piston back into the caliper. It may just be a one time thing. If it happens again, or won't come out once you press it back in again then you may need to rebuild the whole caliper.
Old Sep 24, 2005 | 11:55 PM
GdmLaz's Avatar
k i realised today all brakes are braking front and back brakes even when im not steppin on the brakes
Old Sep 25, 2005 | 02:53 AM
taney's Avatar
put your car on jackstands before you start the car .. when the car is completely cold and cool .. and see if you can rotate any of the tires .. and let me know the results ..
Old Sep 25, 2005 | 12:10 PM
GdmLaz's Avatar
yes you could rotate them when the car is cold and you haven't even mess around with the brakes but once you drive it for a lil while if you put the car up in a jackstand no you won't be able to move none of the tires
Old Sep 25, 2005 | 12:37 PM
GdmLaz's Avatar
neeed help up top
Old Sep 25, 2005 | 03:29 PM
taney's Avatar
it's your master cylinder .. you either have the wrong booster or wrong master cylinder .. either that or something is making the brake fluid overheat and causing your whole brake system to shut down .. tell me how your master cylinder looks like .. where the brake lines go in .. and tell me what's the model number on the brake booster? it looks like a simple case of gsr brake booster (290nm) and rs (non-abs) master cylinder .. the rs master cylinder uses a 260nm .. i tried these mismatched brake boosters and master cylinders on my car .. and since the gsr brake booster has a longer push rod .. it makes the car constantly brake at a slight rate .. and then your brake fluid overheats and locks up the whole system ..
Old Sep 26, 2005 | 03:14 AM
GdmLaz's Avatar
thanks for the info bro i'll go check this out in the morning lol
Old Sep 26, 2005 | 03:18 AM
GdmLaz's Avatar
k i replaced both the master brake cylinder and brake booster the master cylinder says 18/15 on it and the booster i dunno how can i kno what model it is
Old Sep 26, 2005 | 08:07 AM
GdmLaz's Avatar
Up TOP
Old Sep 26, 2005 | 08:30 AM
Targa250R's Avatar
be professional
If all 4 of your brakes are sticking, then you probably need to adjust the rod that goes from the top of the brake pedal through the firewall to the booster & master cylinder.
Old Sep 26, 2005 | 09:16 PM
GdmLaz's Avatar
up top keep suggestions coming lol
toshko321
12
Nov 11, 2009 08:11 PM
jeannylam09
Suspension & Brakes
Nov 21, 2008 11:24 AM
ef.love
Oct 23, 2008 01:33 PM
infamouskillas
Apr 2, 2008 07:32 AM
PabloDiablo
May 30, 2007 06:45 PM
