Anyone in So CaL that can tune Emanage??? Also question on timing control
Old Sep 23, 2005 | 08:30 PM
ToasterOven's Avatar
Default Anyone in So CaL that can tune Emanage??? Also question on timing control
hey guys, I wanted to know if there is anyone in So CaL you have used that can tune an Emanage and tune it well. This will be on a dyno of course and i have my own wideband. setup is 99 civic DX with the Greddy 19t kit. I was also wondering about the ignition control harness that Greddy sells as an add on, can I just use the harness with the stock crank sensor? or do i need to do anything further? also does the harness plug and play or do I have to wire it directly to the crank sensor?
Last question, will I benefit enough from the timing control to buy the harness or will stock timing be safe enough at 10psi?
Thanks for any help!!! beers for everyone
Old Sep 28, 2005 | 07:27 PM
Default Re: Anyone in So CaL that can tune Emanage??? Also question on timing control (ToasterOven)
PumP
Old Sep 28, 2005 | 08:08 PM
jayswift's Avatar
where in socal? i'm pretty sure any shop can tune your emanage. and if you want a full tune then get the injector and ignition harness also.
Old Oct 5, 2005 | 06:54 PM
Default Re: Anyone in So CaL that can tune Emanage??? Also question on timing control (jayswift)
found a shop to tune, Church's. Can't the emanage tune by adjusting the pulsewidth of the 310cc's that come in the kit without the injector harness?
gotzrycefoolio
May 27, 2005 12:01 PM
turboteg2nv
Sep 8, 2004 03:39 PM
94dxt
Dec 23, 2003 07:29 AM
