e-manage, what's needed?
Old Dec 13, 2003 | 01:24 AM
94dxt's Avatar
Default e-manage, what's needed?
What sensors/harnesses do I need for a boostsed car? I don't need the timing retard option (have BTM). Is the base unit, pressure sensor/harness, and inj. harness all I need?
Old Dec 13, 2003 | 01:53 AM
malcolmtat2's Avatar
Default Re: e-manage, what's needed? (94dxt)
If ur plannin to buy all these i have the whole setup except the software
if u interested make me an offer
itz brand new.I didn't use it because I cant find any tuner where i live
Old Dec 13, 2003 | 09:03 AM
p0gi's Avatar
Default Re: e-manage, what's needed? (malcolmtat2)
i would sell the btm and spend the $30 on the harness for ignition. If you plan to run over 11psi get the boost sensor and harness. If you plan to tune yourself get the support tool or an e-01. I would get the injector harness too.
Old Dec 13, 2003 | 10:33 PM
94dxt's Avatar
Default Re: e-manage, what's needed? (p0gi)
What is needed to run 10psi? I am not tuning it so I don't need the support tool
Thanks
Old Dec 15, 2003 | 10:34 AM
RacerSi
Guest
Posts: n/a
e-manage kinda scares me because it seems like a great unit but i havent heard someone give great feedback about it. mostly alot of people sell it.
Old Dec 15, 2003 | 05:42 PM
p0gi's Avatar
Default Re: e-manage, what's needed? (RacerSi)
I give it a I have 2 of them and have a pretty solid a/f ratio on both cars(between 11.8-12.2) . I tuned it myself using a wideband 02 sensor. Its a simple and very effective system that has alot of features. To run 10psi you can use the stock map sensor.
Old Dec 22, 2003 | 02:23 PM
94dxt's Avatar
thanks,
but what sensors/harnesses do I NEED to run >10psi?
Old Dec 22, 2003 | 03:50 PM
p0gi's Avatar
here Ill repost it....... i would sell the btm and spend the $30 on the harness for ignition. If you plan to run over 11psi get the boost sensor and harness. If you plan to tune yourself get the support tool or an e-01. I would get the injector harness too.
All you will need is the injector harness. But why not invest in the ignition harness for $30 since you can control the ignition timing +-20 degrees, and you control it while in vacuum, and not just while boosting.
Old Dec 22, 2003 | 04:12 PM
Bulldogg83's Avatar
I ran the E-Manage on my old setup and made 275whp/218ftlb of torque @ 13lbs....it did alright, but if you are wanting to run over 12 psi then you will need the optional boost harness which is like $120 bucks
Old Dec 22, 2003 | 04:15 PM
streetlvlhatch's Avatar
Default Re: e-manage, what's needed? (Bulldogg83)
does the boost harness avoid using a 3 bar map sensor?
Old Dec 22, 2003 | 04:18 PM
Bulldogg83's Avatar
Default Re: e-manage, what's needed? (streetlvlhatch)
yeah something like that....it cuts into one of the vaccum lines near the map sensor and then there this mini-airbox installed and then there is a wire harness that runs from that to the E-Manage
Old Dec 23, 2003 | 07:29 AM
p0gi's Avatar
the boost harness is for the optional 3 bar map sensor.
Brisco
Honda Civic (2016 - Current)
Nov 15, 2018 02:27 PM
ludedawg2001
Oct 22, 2004 05:20 PM
My95SlvrBlt
Jul 28, 2004 10:32 PM
