Clutch
Old Sep 23, 2005 | 11:23 AM
bman511's Avatar
Default Clutch
I have a ACT extreme pressure plate with a street disc, and a prolite flywheel. It's on my b18c, ok well when i first put it in it the pedal was grabing down by the floor. Well my slave cylinder went out the week after the swap. So i replaced that. Now it doesn't grab until i have the pedal like 75% off the floor, i have bled and bled and bled the slave cylinder so i don't think there is air in the line, and the clutch still grabs good, but i just want it to grab down by the floor, could this be my Master cylinder going out? Is there something that needs to be adjusted after the clutch is broken in? This clutch is about 6 months old! Thanks in advance!
Old Sep 23, 2005 | 02:36 PM
kodirtysi's Avatar
Default Re: Clutch (bman511)
bump
Old Sep 23, 2005 | 03:42 PM
wwang924's Avatar
Default Re: Clutch (kodirtysi)
the master cylinder is pretty easy to check if it is going out, it will leak on the inside by the firewall. I searched, did the check, and sure enough my MC is leaking.
Old Sep 23, 2005 | 09:13 PM
bman511's Avatar
Default Re: Clutch (wwang924)
thanx and i'll post tomorrow after i look.
Old Sep 23, 2005 | 09:14 PM
bman511's Avatar
thanx for the website as well, it's loaded w/info.
hYbRiD EeEkAy
Aug 7, 2008 11:27 AM
jaywo_23
Oct 11, 2007 08:49 PM
RDAYA0
Dec 14, 2006 05:31 PM
Pandahatch
12
Aug 24, 2004 07:48 AM
myhatchrips
Dec 5, 2003 07:21 AM
