help needed on a civic swap
Old Sep 23, 2005 | 10:00 AM
jdm2teg's Avatar
Default help needed on a civic swap
well my friend has been working on his civic forever. we put a 1999 gsr motor in his 2000 civic with si harnes. we seem to did everything right. only problem is it doesnt start. all it does is jus crank and it gives no spark. we changed the sparkplug, wires, and a brand new distrubitor and guys still no spark. i think it has something to do with the harness on distrubitor. what do you guys think. and if anyone can i would like to know what is each of the wires are going in the distrubitor. thanks. please need of help.
Old Sep 23, 2005 | 02:36 PM
kodirtysi's Avatar
Default Re: help needed on a civic swap (jdm2teg)
Bump
Old Sep 23, 2005 | 03:37 PM
transpar_nt's Avatar
Default Re: help needed on a civic swap (kodirtysi)
are you sure you have the spark plugs wires connected correctly?
are you sure it's a spark problem? Could it be fuel (or lack thereof)?
Old Sep 23, 2005 | 03:59 PM
the jdmchop's Avatar
Default Re: help needed on a civic swap (transpar_nt)
well first start off with the basics!
do we have fuel?
do we have spark?
do we have compression?
those are a good start
is the pump turning on?
do you have all good grounds? drove me nuts wen i totaly forgot about my grounds when i did my swap
start with those then well work from there
dam i sound like my old teacher
Old Sep 23, 2005 | 05:49 PM
jdm2teg's Avatar
Default Re: help needed on a civic swap (jdmchop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmchop &raquo;</TD></TR><TR><TD CLASS="quote">well first start off with the basics!
do we have fuel?
do we have spark?
dam i sound like my old teacher </TD></TR></TABLE>
fuel check
spark nop
eveerything is there except for spark.
u guys think its the herness. i am using si herness. but some wires were missing so we added it from another si herness and put it on. because the other herness were missing alot mo **** then the one i am using. thanks.
Old Sep 23, 2005 | 06:16 PM
is everything pluged in?
if so check to see if there is power to the dizzy and check the grounds on it
maybe the dizzy is bad
Boosted96gsr
Jan 9, 2012 08:04 PM
j4s0n1337
41
Feb 19, 2011 07:50 PM
JAYDmManny1331
Nov 22, 2009 09:33 PM
Robs_B18c
Nov 19, 2009 08:34 AM
jdm2teg
Sep 23, 2005 01:13 AM
