h22 help please
Old Sep 23, 2005 | 09:14 AM
huge230's Avatar
Default h22 help please
I went to start up my h22 today and nothing. it will turn over all day but thats it. I thought it was wired right. I cant see any spark coming out of the plug wires. any ideas? please help
Old Sep 23, 2005 | 09:20 AM
mckenzie's Avatar
Default Re: h22 help please (huge230)
from what i have read, main relay or icm
Old Sep 23, 2005 | 01:14 PM
huge230's Avatar
Default Re: h22 help please (superpho)
one person told me coil? would that be it?
Old Sep 23, 2005 | 01:30 PM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by huge230 &raquo;</TD></TR><TR><TD CLASS="quote">one person told me coil? would that be it?</TD></TR></TABLE>
it could be. there are a lot of things it could be. need more detailed info to make more educated guesses.
Old Sep 23, 2005 | 01:36 PM
huge230's Avatar
Default Re: h22 help please (IHateJDM)
what kind of info
Old Sep 23, 2005 | 01:39 PM
IHateJDM's Avatar
things that you have tried, or can give us more clues. How did you check for spark? do you hear the fuel pump prime when you turn the key? can you smell gas by the injectors after trying to start it? How long has it been since you replaced: fuel filter, dizzy cap + rotor, plugs + wires? Any cels?
Old Sep 23, 2005 | 01:46 PM
huge230's Avatar
i was just looking for spark with a plug of. It is getting fuel because there was a leak at first. The cap was a JDM one that came with the engine. It has never been started by me before. I dont have a code reader so I dont know about codes. The plugs are also the JDM ones that came with the engine. dont know if this helps or not
Old Sep 23, 2005 | 01:48 PM
IHateJDM's Avatar
so you just swapped it in? what ecu are you using?
Old Sep 23, 2005 | 01:49 PM
huge230's Avatar
ya, im using a P13
Old Sep 23, 2005 | 01:52 PM
IHateJDM's Avatar
what chassis? do you know if the motor is obd1 or 2? If obd1, did you wire in a resistor box?
Old Sep 23, 2005 | 01:53 PM
huge230's Avatar
ya its OBD 1 and the resistor box is in. I assume it is working but dont know how to actually check if the injectors are firing, cause I guess there can be fule pressure and them not firing
Old Sep 23, 2005 | 01:56 PM
IHateJDM's Avatar
if its not working/wired wrong, either the resistor box, or your ecu will get really hot. try the screwdriver trick for checking spark. pull a plug wire and hold it next to the metal part of a screwdriver. ground the other end of the screwdriver and look for spark while someone else tries to start the car.
Old Sep 23, 2005 | 01:58 PM
huge230's Avatar
ok thanks for your help. how do I ground the other end of the screwdriver? wont the handle ground it? thanks again buddy
Old Sep 23, 2005 | 02:00 PM
IHateJDM's Avatar
your valve cover has a ground. just touch the tip of the screwdriver to the wire that connects the valve cover to the body. the handle does not ground it. Also, check to make sure your grounds are all good. a weak ground can keep the car from starting.
Old Sep 23, 2005 | 02:01 PM
huge230's Avatar
ok thanks. ill get bacl to you later if you dont mind
Old Sep 23, 2005 | 02:02 PM
IHateJDM's Avatar
i'm not always on h-t, but if i'm here i'll help out. plus, as you add more info to this thread, more people will be willing to offer advise. good luck.
Old Sep 23, 2005 | 08:06 PM
lak8's Avatar
ive pretty much had the same probably as you. first time i went to start her up nothing, no spark. I thought what next... more problems. I pulled out the multimeter and started probing, turns out it was the coil. From what ive read h22 jdm engines are almost notaries for bad internal coils and the ignitor sometimes going. Also make sure all your grounds are good, an important one is the ground by the thermostat. Good luck
Old Oct 1, 2005 | 11:00 AM
huge230's Avatar
Default Re: h22 help please (lak8)
i cant get any readings on the coil but not 100% sure if im probing right.
Old Oct 1, 2005 | 11:03 AM
huge230's Avatar
will this coil work?
http://cgi.ebay.com/ebaymotors...QrdZ1?
5speeder
Nov 7, 2011 04:07 PM
JTCdudeman
Apr 18, 2006 07:00 PM
huge230
Oct 1, 2005 11:00 AM
cheezoto
Dec 27, 2004 10:33 PM
yuckymucky
Mar 23, 2003 02:12 PM
