Need to Install A/c condenser...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by galaxykid70 »</TD></TR><TR><TD CLASS="quote">easy to install,
make sure u have no freeon in ur lines,
2 10mm bolts and undo a cople misc, stuff.
das it.</TD></TR></TABLE>
Technically there should never be freon in his a/c system.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmsrally »</TD></TR><TR><TD CLASS="quote">Sounds easy enouph
I understand I will need..
-condenser $100-120
-o-rings $?
-SUVA $15
-oil You can purchase refrigerant with poly alkaline glycol all ready in it $?
-any special tools?
Is there any DIY how to's anywhere?</TD></TR></TABLE>
-condenser $100-120
-o-rings $?
-SUVA $15
-any special tools?
If you need a condensor, i have one off of my 99-00 si.
email em1project@cfl.rr.com if you're interested. If not, it's cake to do, will take like 5-10 min.
well i work at a dealership, its $75 hour. they charge so much b/c if a certified tech installs it it comes with a warranty. there is a book with all the labor times in it. so there it labor to replace the condensor and then also to evac and racharge the ac system. they are supose to follow a certain procedure in order to replace it like get all the stuff outta the ac lines and them take it off, the put back on, and evac and recharge. hope this helps!
Powered by VTEC
Jan 26, 2008 09:03 PM
