OBD2 in EF NEED HELP
No, I can't just run OBD0 or OBD1, for this engine work at all I need to run the proper ECU
so hear is what I have:
-96 D15B 3-stage vtec engine
-OBD2 P2J ECU (the one for that engine)
-OBD0 to OBD2 jumper harness on order
-OBD0 harness off of HF engine
I need to Either convert my HF harness (round holes)to that engine(square plug)
or, convert the obd2 harness to (square plug) to the EF chassis (round holes)
My concerns:
-Fuel injectors (what do I need to do, and where do I look)
-Distributer plug (I don't think my harness will plug into this distributer)
-Misc other plugs (what other plugs will I need to redo? MAP? TPS?)
Please help me with some of the details, I belive most of the same stuff applies to OBD0 to OBD1
where can I find a wiring diagram????
My concerns:
Give me a call... YOU MUST USE THE HARNESS FROM YOUR CAR dont even try some random hf, or obd2 engine harness. It must match... Ill tell you how to wire it over the phone, or you can choose to order from us.
Ryan
Ryan
I think I have my injectors wired, now how about everything else, distributer... the instructions say "big white wire ... and white wire, both of my white wires are the same size....) also I'm looking at the alternator the plugs are diffent but both are 4 wire, How do I swap plugs.
Sinner
Jan 4, 2006 05:28 PM
