Blown B16! What happened?
Old Sep 22, 2005 | 09:59 PM
EF7's Avatar
EF7
Default Blown B16! What happened?
My engine just blew up, it started to burn antifreeze (white smoke) and then I felt a significant loss of power. When I got home I sprayed water on the exhaust ports and #1 is cooler that the other three. What happened? I did not hear any load noises and there is no knocking sounds like when a connecting rod snaps. Any ideas?
Old Sep 22, 2005 | 10:17 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Blown B16! What happened? (EF7)
Blown head gasket. Check your compression.
Old Sep 22, 2005 | 11:02 PM
mmuller's Avatar
Mad Scientist
Default Re: Blown B16! What happened? (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">Blown head gasket. </TD></TR></TABLE>
thats what it sounds like..
take out the spark plug, inspect, also look inside the bore when the piston at tdc.
if your hg. blew like that that cyl. should be clean as so the srapk plug
Old Sep 24, 2005 | 04:07 AM
EF7's Avatar
EF7
I removed the spark plugs and all four are black; i looked inside the piston at TDC and it is not clean either. I am going to do a compression test.
Old Sep 24, 2005 | 08:29 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">Blown head gasket. Check your compression. </TD></TR></TABLE>
I would also agree that the head gasket blew out.
Old Sep 24, 2005 | 01:43 PM
hondaxsimike's Avatar
anytime yer burning coolant like that, the number one cause is the headgasket.
Old Sep 24, 2005 | 08:03 PM
IMALLSLO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF7 &raquo;</TD></TR><TR><TD CLASS="quote">I removed the spark plugs and all four are black; i looked inside the piston at TDC and it is not clean either. I am going to do a compression test.</TD></TR></TABLE>
Instead of a compression,do a leak down. Warm vehicle to operating temperature. Then when warm set each cylinder at TDC and apply psi to the cylinder. Make sure the radiator cap is off and radiator topped off. A blown headgasket will cause to coolant to rise out of the radiator. This pinpoints the bad cylinder and verifies the problem a 100% of the time. Good luck!
Old Sep 25, 2005 | 04:14 AM
EF7's Avatar
EF7
Thanks for the help, I am going to run a leakdown test I just have to find a test set first.
jdmek2277
11
Sep 9, 2008 07:44 PM
EG2Driver
Sep 4, 2006 07:35 PM
Dohcvtec59
Sep 8, 2004 06:32 PM
aspeed
Aug 8, 2004 06:17 AM
JBet
Jun 5, 2002 04:12 AM
