sheet metal intake install now won't idle
Old Sep 22, 2005 | 06:34 PM
accordlove's Avatar
Default sheet metal intake install now won't idle
the engine is a ls vtech computer is aem. the car will only idle when the throttle is held at 10%. there is a port for a vaccume source were the iac is i blocked it off thinking it whould leak vaccume. could this be the problem. thanks
Old Sep 22, 2005 | 06:58 PM
Full-Race Geoff's Avatar
Default Re: sheet metal intake install now won't idle (accordlove)
do you have an IAC hooked up? If there is no IAC your car is not going to idle well, at all
Old Sep 22, 2005 | 07:43 PM
accordlove's Avatar
Default Re: sheet metal intake install now won't idle (Full-Race Geoff)
its hooked up. i think the vaccume source that is blocked off is the problem. its my friends car and i cant go mess with it un till friday.
here is the vaccume source it goes right to the iac port.
Modified by accordlove at 9:02 PM 9/22/2005
Old Sep 22, 2005 | 08:17 PM
that is one hanus lookin intake mani. wtf is that tube supposed to do
Old Sep 22, 2005 | 08:19 PM
accordlove's Avatar
i think it might be for the iac, mybe it lets more air in at idle?
Old Sep 22, 2005 | 10:08 PM
project dc2's Avatar
its for the IAC> u leave it open so the iAC can get air to let the motor idle a bit better. IMO its too ******* small and deosnt do ****. you shoudl tap it and build a lil plate and give the IAC a bigger vac source. OFF the intake manifold !
Old Sep 23, 2005 | 10:01 AM
accordlove's Avatar
Default Re: sheet metal intake install now won't idle (project dc2)
thank you.
deb1991
Aug 14, 2011 11:03 AM
civicek3
Feb 22, 2010 07:42 AM
fresheg760
Jun 7, 2008 06:33 AM
booja
Apr 17, 2006 03:50 PM
s2k
Feb 25, 2003 06:50 PM
