odb2-1
Old Sep 21, 2005 | 10:09 PM
antivic's Avatar
Default odb2-1
i'm puttin a obd1 jdm b16a in a 99 ex...i'm not worried about ecu, alternator or injectors...just the dizzy, mainly the ckp...how would i wire that **** up...i'm using a 99 si computer, and i know i'ma throw the code for it...and the kid that i'm doin the swap for doesn't have the funds for a conversion harness...help a brother out!
Old Sep 22, 2005 | 07:54 AM
antivic's Avatar
Default Re: odb2-1 (antivic)
anyone?? =[
Old Sep 22, 2005 | 08:25 PM
The Clash's Avatar
You have to use an OBD2 B series oil pump (has mount for the Crank fluc. sensor) and then add the sensor. There are no issues with OBD1 to OBD2 dizzy's - internally they are the same, just different plug styles. You can use the OBD1 dizzy if you change the plugs to match the harness, or you can get a OBD2 VTEC dizzy for plug and play.
sumoneEK
25
Nov 2, 2010 07:55 AM
CivicTT
Jan 7, 2010 07:43 AM
Cyphear
Jul 13, 2007 03:58 PM
SPOOLINmatt
May 18, 2006 10:28 AM
DetainedCivic
Apr 17, 2006 10:52 AM
