QUESTION ABOUT MOTOR
Old Sep 21, 2005 | 10:04 PM
lv6l's Avatar
Default QUESTION ABOUT MOTOR
i'm planning to buy a motor. i saw a d16a but it says 96 and up. would it fit onto a 92-95 eg? or would it fit but the obd wont be the same. thanks.
Old Sep 22, 2005 | 01:02 AM
lv6l's Avatar
BUMP
Old Sep 22, 2005 | 01:06 AM
DestructoEH's Avatar
Default Re: QUESTION ABOUT MOTOR (lv6l)
If it's a 96+ motor, you would need an OBD1-OBD2 conversion harness... along with the ecu of course. I've never done a conversion like that, but as many ads as I see on this site for conversion harnesses, I'm sure it couldn't be too hard. It's sounds like its PnP. Anyone care to elaborate?
Old Sep 22, 2005 | 02:51 AM
siregcivic's Avatar
why not just switch over all the sensors and stuff from the obd1 motor to the obd2 motor to make it work??? obd2 computers suck.. why make a car obd2????
thats what i would do... swap injectors idle air controll valve.... map tps.. dizzy... water temp... everything just swap it over
Old Sep 22, 2005 | 09:26 AM
lv6l's Avatar
oh, but there is a d16a out there that is obd1 right? is it harder to go from obd1 to obd0 and is obd0 good?
Old Sep 22, 2005 | 10:42 AM
IHateJDM's Avatar
Default Re: (lv6l)
you want to be obd1 for ease of install and potential tuning purposes. the obd1 single cam vtec was the z6 (d16z6), obd2 was y8. Try to find a z6 if you can.
bzoe1
Aug 3, 2009 12:44 PM
BoltonGSR
Jun 13, 2008 08:49 PM
soon2bdropped
Aug 30, 2007 10:32 AM
blackedoutcivic
Jan 29, 2003 08:17 PM
