How to check for code
Old Feb 28, 2002 | 09:16 PM
SlowB16's Avatar
Default How to check for code
I have a p72 OBD1 gsr ecu. How do I check the code it is throwing? I know you stick something in somewhere and look for a light, but other than that I have no idea....
Old Feb 28, 2002 | 09:25 PM
bearingburner's Avatar
Default Re: How to check for code (SlowB16)
BLUE CONNECTOR BY PASSENGER KICK PANEL . PUT PAPERCLIP TO TWO TERMINALS AND TURN KEY TO POSITION 2 DO NOT START.
Old Mar 3, 2002 | 02:03 PM
SlowB16's Avatar
Default Re: How to check for code (bearingburner)
I dont understand that. Anyone else
Old Mar 3, 2002 | 02:43 PM
Kamin's Avatar
lol some people....
here.
To check the code, Take off the passenger side kick panel and look above your ECU (the metal box). find the green rubber housing
with a blue connector (looks like the end of a telephone cord). Get a piece of wire like a paperclip, and
bridge both connections. Now turn your key just before you have to start the car, watch your CEL and get the code.
If the CEL blinks fast, that stands for 1, 2, 3, etc. If it is a long blink, that stands for 10, 20, etc. The code
will recycle, just in case you don't get it the first time. also, there could be multiple codes.
Old Mar 3, 2002 | 03:08 PM
SlowB16's Avatar
Default Re: How to check for code (KAMiN)
So you just hold the same paperclip to two seperate points?? This seems easy enough
Old Mar 3, 2002 | 07:48 PM
shamoo's Avatar
Will you make something up for me please?
Use this: http://www.bseries.net/html/garage/engcode.php
Old Mar 4, 2002 | 05:20 PM
SlowB16's Avatar
Default Re: How to check for code (shamoo)
thanks, that makes it easier
suprant0010
Apr 19, 2014 02:41 AM
Used2beAb16
May 4, 2005 07:16 PM
Log4n
Mar 15, 2003 05:11 AM
b18civic
Feb 18, 2002 03:58 AM
b18civic
Feb 12, 2002 03:48 AM
