is it necessary to mill down a head when you rebuild an engine?
Old Sep 20, 2005 | 02:36 PM
RACEPAK's Avatar
Default is it necessary to mill down a head when you rebuild an engine?
as topic says thanks.
Old Sep 20, 2005 | 02:46 PM
Lord Helmet's Avatar
Default Re: is it necessary to mill down a head when you rebuild an engine? (RACEPAK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK &raquo;</TD></TR><TR><TD CLASS="quote">as topic says thanks. </TD></TR></TABLE>
Only if it's out of spec. And only to factory specs. milling the head beyond the factory specs throws the timing way off which makes it a nightmare to tune. It's best to deck the block instead of milling the head too much.
Old Sep 20, 2005 | 02:52 PM
RACEPAK's Avatar
Default Re: is it necessary to mill down a head when you rebuild an engine? (Lord Helmet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lord Helmet &raquo;</TD></TR><TR><TD CLASS="quote">
Only if it's out of spec. And only to factory specs. milling the head beyond the factory specs throws the timing way off which makes it a nightmare to tune. It's best to deck the block instead of milling the head too much. </TD></TR></TABLE>
thank you for the answer but what is "deck the block"?
Old Sep 20, 2005 | 04:11 PM
slomofo's Avatar
GDD Member
Decking the block is just like milling the head, but for the block surface.
Old Sep 20, 2005 | 04:13 PM
rainforest's Avatar
the same thing as milling a head but doing it to the block. Its done to make sure the mating surfaces are stright on.
dkk119
Northeast (Sales)
Jun 22, 2006 02:08 PM
hanseljohn
21
Sep 11, 2005 10:13 AM
cvp467
Jul 17, 2005 02:00 PM
redcrx187
75
Jul 21, 2004 09:27 PM
hb4u2nv
Jun 10, 2004 09:43 PM
