Another Q: HT probably can't answer..... :(
Old Sep 20, 2005 | 01:51 PM
ThatsMyEG's Avatar
Default Another Q: HT probably can't answer..... :(
ok i have a 92 hb, b20 block, im rebuilding my motor i was told the 92 hatchs dont have crank angle sensors??.... my question is, will a 99 gsr oil pump work on my block i heard it will but the timing belt cover wont fit?? is this info true??
Old Sep 20, 2005 | 01:55 PM
Luserkid's Avatar
Default Re: Another Q: HT probably can't answer..... :( (ThatsMyEG)
OBD1 CAS is in the dist. On OBD2 cars there put in externally next to the crank. As for your cover im pretty sure yours will fit because there built the same way. Only thing is if you run a CAS like OBD2 then it might hit, but without one there itll fit.
boosted k20
Oct 16, 2017 11:11 PM
CivicTT
Jul 12, 2010 01:29 PM
BIG RICH
Jul 3, 2006 09:31 AM
tgreaves
Mar 13, 2006 05:32 AM
hackish
Oct 14, 2005 11:30 AM
