Proof of gains from turbo rebuild (another stock ignition dyno)
Old Sep 20, 2005 | 08:18 AM
servion's Avatar
Default Proof of gains from turbo rebuild (another stock ignition dyno)
Well, I previously posted the dyno chart from my personal car about a month ago. When I did that dyno, I simply unplugged my boost controller (which, with my current controller, causes maximum boost). That's the blue line.
The red line is the same car (same setup) with everything the same except that the turbo was rebuilt and the car was retuned. The boost was also controlled with the boost controller maxxed out, so the new red lines are on less boost (I would guess 2-3psi, but its hard to tell because of the large difference between gauge pressure and absolute pressure here).
The new pull goes to around 9.5k, I would have liked to pulled it to 10k or further; I'll think try that next time out
Setup: very simple
Stock bore b18c, LS crank
CP pistons, full-race rods
Old-school (I mean really old, but still holding strong) full-race prostreet manifold
t3/t67, .63 hotside
3" full-race DP, 4" JouleSpeed exhaust
The only differences:
1) rebuilt turbo
2) removed the MSD 7al in place of a 100% stock ignition system with nothing but a blaster 3 coil wired directly to the distributor (I was motivated by Jeff Evans' most recent posts to try it out)
3) retuned by me
It feels so much smoother on the stock ignition system with the blaster coil too, which I thought was very strange. The tune changes were more drastic than I expected them to be.
Old Sep 20, 2005 | 08:21 AM
RobbieG35's Avatar
12 Years Strong
Default Re: Proof of gains from turbo rebuild (servion)
Congrats.
Old Sep 20, 2005 | 08:27 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: Proof of gains from turbo rebuild (HybridHatch88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridHatch88 &raquo;</TD></TR><TR><TD CLASS="quote"> Congrats. </TD></TR></TABLE>
Sickness!
Old Sep 20, 2005 | 10:39 AM
Quad-Damage's Avatar
Default Re: Proof of gains from turbo rebuild (boostincoupe)
what boost controler?
Old Sep 20, 2005 | 10:44 AM
servion's Avatar
I'm still using the oldschool greddy profec-b (not the spec 2, its the original one)
Old Sep 20, 2005 | 12:06 PM
Default Re: (servion)
im using the same one whats the max boost it can control? 18 psi?
Old Sep 20, 2005 | 12:10 PM
servion's Avatar
It all depends on your setup (wastegate, wastegate spring(s), manifold, turbo, etc.) The controller isn't the limiting factor
Old Sep 20, 2005 | 12:19 PM
Adam.C's Avatar
nice power. must be fun
Old Sep 20, 2005 | 04:10 PM
H.A.R.T B18C1EG6's Avatar
Default Re: Proof of gains from turbo rebuild (orangerex04)
Rod.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orangerex04 &raquo;</TD></TR><TR><TD CLASS="quote">nice power. must be fun</TD></TR></TABLE>
Old Sep 20, 2005 | 04:42 PM
adseguy's Avatar
Default Re: Proof of gains from turbo rebuild (Rod.)
"Stock ignition" is the new "stock sleeves"!!!
I'm loving it!
Old Sep 20, 2005 | 05:55 PM
rhd's Avatar
rhd
is this a sleeved block?
Old Sep 20, 2005 | 07:41 PM
tegedrex's Avatar
Default Re: (rhd)
Yes its a Bensen sleeved stock bore.
Congrats again Jeremy on the numbers and the big win this last weekend...
Old Sep 20, 2005 | 08:07 PM
FredoSP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by servion &raquo;</TD></TR><TR><TD CLASS="quote">I'm still using the oldschool greddy profec-b (not the spec 2, its the original one)
I still remember that one, gangster!!
Old Sep 20, 2005 | 10:11 PM
Redwidow's Avatar
What type of bearing was used for your rebuild on the turbo? I know if you have a FR turbo they state they use the 360 degree thrust bearing. I hear it was a bit off balanced and looks like your spool time is better...
Jan 22, 2008 07:42 AM
bigdgsr
Jul 7, 2006 09:09 AM
Rod.
Sep 5, 2004 08:49 AM
