stroked d16???can it be done???
Old Sep 19, 2005 | 05:07 PM
memphosfinest's Avatar
Default stroked d16???can it be done???
i have a d16z6 and want some more horse power.i was thinking about puttong b18c1 pistons and crank witha new comp cam??will i have to machine on the block and is it worth it???will rhe crank fit without major modification??how much horse power will these give me???any info will help??
Old Sep 19, 2005 | 05:08 PM
Kyles ej1's Avatar
Default Re: stroked d16???can it be done??? (memphosfinest)
dude dont do it. for that money you could have a ******* quick *** d16 turbo.
you will prob gain like 25 hp
Old Sep 19, 2005 | 05:11 PM
tat suks.ill just get a turbo then.thanx
Old Sep 19, 2005 | 05:52 PM
Mista Bone's Avatar
D Tranny Guru
You understand it costs $2000 to fit the GSR pistons iontot the block, then the motor MIGHT last 100 miles.
I've heard of it being done ONCE, engine only lasted 3 pulls on the engine dyno before the sleeves split.
Old Sep 19, 2005 | 06:03 PM
Soccerking3000's Avatar
Default Re: (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">You understand it costs $2000 to fit the GSR pistons iontot the block, then the motor MIGHT last 100 miles.
I've heard of it being done ONCE, engine only lasted 3 pulls on the engine dyno before the sleeves split.</TD></TR></TABLE>
lol good stuff, even with aftermarket sleeves that would be too large of a bore there wouldnt be any space for anything lol especially coolant
Old Sep 19, 2005 | 06:47 PM
Mista Bone's Avatar
D Tranny Guru
thats what happened. They had a 79mm sleeved NA block, scored the walls......junk.......
So lets go 81mm and try the LS stockers.....
Damn crazy canucks
Old Sep 19, 2005 | 07:09 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by memphosfinest &raquo;</TD></TR><TR><TD CLASS="quote">i have a d16z6 and want some more horse power.i was thinking about puttong b18c1 pistons and crank witha new comp cam??will i have to machine on the block and is it worth it???will rhe crank fit without major modification??how much horse power will these give me???any info will help?? </TD></TR></TABLE>
You can get a reliable 1690cc and run 10psi boost on the stock 2001+ D17 crank/rods/pistons, and they swap into your Z6 with moderate but simple work.
Old Sep 19, 2005 | 07:55 PM
Default Re: stroked d16???can it be done??? (Jim Truett)
if anything for a d16 i would bore it to something like 78mm and then destroke it so its crazy rev happy
Old Sep 19, 2005 | 07:59 PM
Jim Truett's Avatar
Default Re: stroked d16???can it be done??? (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">if anything for a d16 i would bore it to something like 78mm and then destroke it so its crazy rev happy </TD></TR></TABLE>
Sounds like a smaller version of a B16. No Torque.
I have a tiny turbo on my stroker and hit more torque than a H22 makes in horsepower by 6000 rpm.
Old Sep 19, 2005 | 08:03 PM
i make more hp and torque than an h22 makes ever before 5000 rpm whats your point
Vspronk
Sep 26, 2015 09:35 PM
knuckk
Jan 13, 2008 05:23 PM
JFG Kevin
Northern California (Sales)
11
Sep 17, 2006 09:30 PM
DOHClessEF-9
May 20, 2005 11:19 PM
Babybluegsr92
Jan 27, 2002 10:04 PM
