AEM EMS: Cold start problem on new motor - need help!
Hi all,
My freshly built motor will not start when the motor is cold when using my AEM EMS.
Setup:
F23A1
8.5:1 CP pistons/crower billet rods
AEM EMS 30-1010 w/ GM 3 bar MAP
RC 750 cc injectors
techedge 2A0 wideband
Once I get it to start (via pop-start or rediculously violent persistance) it runs and runs well.
The weirdest part: If allowed to warm up fully the car will start up again right away. No problem at all.
I used this EMS on the previous (blown) motor and never had a starting problem. It sat out in the car for about 6 months unused while I got the motor together.
I was told my cam/crank sensor is not reading right during start conditions and to try a different distributor:
I've tried three different distributors with the same exact result - no start.
I've torn the engine down to the timing belt & inspected the crank sensors. Found no problem at all.
Changed back to the stock ECU, MAP, and stock injectors and the car will start up immediately every time, cold or warm, doesn't matter. No CELs on the stock ECU.
Swapped the AEM box back into the car w/ the stock injectors & MAP, uploaded a basemap for my car in stock form, and wham: no-start condition.
Swapped the stock ECU right back in and it started right up - no CELs.
Can someone please push, kick, or drag me in the right direction? I have no clue what to do next. Thanks!
-B
(I tried to post this on the AEM forum, but it's down??)
Setup:
F23A1
RC 750 cc injectors
-B
Definetly try lowering your crank injector time table, I've had to lower mine from 80 to around mid 50s for a better cold/warm startup. Just make sure to try it hot/cold startup when you change it a lot to make sure it still starts ok in both conditions.
shoot me an email w/a log and you cal... i had a 99 accord doing the same thing here. took a little time but i got it straight, might be able to do the same thing to yours..
try adding fuel around 10% at a time to your warm up enrichment unitil it idles. you afr's should be on the rich side(12.5ish) and rpm in the 1300-1500rpm. follow the temp and add fuel when its starts to idle rough. for example, I have an evo and i'm running about 80% enrichment right at cold start tapering. I/m me with any other questions.
Originally Posted by 0x64
Looks like AEM is working on their forum software. Can you post a cal and a datalog?
What parameters would you all like to see logged?
Regarding the cal - I can send my current cal, but the car won't start with a basemap either running all stock components, so I'm starting to feel like it's not the calibration, but maybe something w/ the wiring?? I don't know... <sobs softly> LOL
Originally Posted by Jared
did you re zero your timing with the new engine?
Originally Posted by Tooned
Could there maybe be a issue in your Crank time table or the warm up enrichment tables. i know I had a hard time starting my car when warm so I took some fuel outta the crank time table.
Originally Posted by timg
Is the start sync coming on while you're cranking when cold?
Thank all for the input, keep it coming!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg »</TD></TR><TR><TD CLASS="quote">idle position, idle learned, o2, rpm, engine load, engine speed, coolant temp, air temp </TD></TR></TABLE>
during a no-start condition or running? I can't guarantee that I can get it to start at all.
right now I still have the 240c stock injectors installed - supposed to rain tonight so won't be changing injectors, but I'll try to get these values w/ the stock injectors & accord basemap, is that worthwhile?
done, you've got email on your gmail account J. thanks for any help. let me know if you need another log and I'll get it to you.
start sync *does* come ON almost right after I start cranking the motor over.
forgot to mention this I think: the car seems to want to start when I let go of the key. It will crank and crank but nothing at all happens, when I let go of the key it "shudders" like it wanted to start but I let go too soon?!?
