biggest shot of nos on 1.6 SOHC
Old Sep 19, 2005 | 03:25 PM
TSM's Avatar
TSM
Default biggest shot of nos on 1.6 SOHC
I was just wondering. I was planning on changing the rotating assembly and jucing the motor I want to hit it with big shot with a fogger system . Just wanted some feed back . Thanks Tom
Old Sep 19, 2005 | 03:27 PM
hondaxsimike's Avatar
Default Re: biggest shot of nos on 1.6 SOHC (TSM)
if youre talking about a bottom end rebuild, then a wet kit will suit your needs better. with good rods and forged pistons you should be able to run 150 shot no prob. and maybe more than that with good tuning
bnut510's Avatar
what kind of setup u got on that sohc? i could tell u with stock motor, u could probably go witha 60 shot single fogger wet system. built motor could handle alot more tho... depending on your setup
Old Sep 19, 2005 | 03:39 PM
TSM's Avatar
TSM
Haven't got it yet I want to get 90's CRX and hit it with a 300 shot stright drag car all forged internals. I want to make it work and know its not going to be easy .
Old Sep 19, 2005 | 04:15 PM
Steve91's Avatar
Default Re: (TSM)
l would look into a 2 stage setup to help with traction. A single fogger first stage followed by a direct port second stage would be nice. 100hp on the first stage followed by another 125 on the second would be nutty.
Old Sep 19, 2005 | 04:26 PM
TSM's Avatar
TSM
that sounds good do you think i could hit the 11's, I was going to use slicks and a nitrous contoler to eliminate the wheel spin
Old Sep 21, 2005 | 05:59 PM
TSM's Avatar
TSM
I know iam going to make it work
Old Sep 21, 2005 | 08:19 PM
1700anddroping's Avatar
Default Re: (TSM)
you need to check out some of my threads about the juice.
harv
spraying 400 direct port pro race fogger...out of the hole? spinning plum to the
330 and still running 7.12 @ 104.....w/1.52 60'....only thing taken out of the car was the p/s seat and back seat....bottle pressure was 1300...
Old Sep 22, 2005 | 06:04 AM
ghostofnyc's Avatar
harv knows his **** listen to him
Old Sep 22, 2005 | 01:37 PM
TSM's Avatar
TSM
How can i check them out search your name I really want to make it work
Old Sep 22, 2005 | 01:46 PM
Default Re: (TSM)
pm'd you.let me know how i can help.
harv
sean-sports
Sep 9, 2009 08:39 PM
924doorEG
17
Oct 22, 2007 08:20 PM
TheDelSlo
Feb 13, 2006 09:16 PM
Blue97GST
Dec 23, 2003 08:05 AM
bogus_ek
Dec 4, 2003 05:51 PM
