this is dumb...how to bleed coolant?
Old Sep 19, 2005 | 02:47 PM
hanson said's Avatar
Default this is dumb...how to bleed coolant?
when the search function is down, i guess there's bound to be a rise in stupid questions.
i've got a 96 b18b with a surging cold idle, and i'm needing to bleed the coolant after cleaning out my iacv and bypassing my fitv.
basically, how do you bleed the coolant system? as far as i can see, i have no bleeder valve, and i remember there being one on the thermostat housing on my mom's 96 teg.
fast help would be appreciated. i'm ready to solve this stupid problem.
Old Sep 19, 2005 | 02:52 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: this is dumb...how to bleed coolant? (hanson said)
Well, I guess a simple bleeding job would consist of:
1. Fill up the radiator with coolant/water until the top.
2. Start the car and have it run until the thermostat opens up.
3. When the level of the coolant mixture has dropped, fill it up more.
4. Cap off radiator.
5. Fill up reservior container until the mark on the side.
Is that what you were looking for? There are places where you can go where they will flush your coolant. But you need a machine for that, I believe.
Old Sep 19, 2005 | 02:56 PM
Default Re: this is dumb...how to bleed coolant? (shamoo)
this will remove all the air?
i figured this was the way to do it, i just wanted to be certain.
Old Sep 19, 2005 | 03:03 PM
crx_88_si's Avatar
you can also squeeze the rad hoses (big ones, upper hose) to help push the air out.
Old Sep 19, 2005 | 03:08 PM
temp's Avatar
Default Re: (crx_88_si)
sometimes there is a bleeder valve, follow the upper radiator hose to where it connects to the head, if there is a nipple lookin thingy there (technical term :-P) crack er open and it will bleed the air out of the system thru there.
Old Sep 19, 2005 | 03:27 PM
Shoobie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">Well, I guess a simple bleeding job would consist of:
Is that what you were looking for? There are places where you can go where they will flush your coolant. But you need a machine for that, I believe.</TD></TR></TABLE>
Forgive my n00bness, but:
1) Do you leave the radiator uncapped when you run the car? (between steps 1 and 2)
2) How do you know when the thermostat has opened?
Old Sep 19, 2005 | 03:28 PM
temp's Avatar
Default Re: this is dumb...how to bleed coolant? (Shoobie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shoobie &raquo;</TD></TR><TR><TD CLASS="quote">
2) How do you know when the thermostat has opened?</TD></TR></TABLE>
yes leave it uncapped
Old Sep 19, 2005 | 03:53 PM
dpetro1's Avatar
the lower rad hose will get hot and then eventaully the fan will kick on
Old Sep 19, 2005 | 03:58 PM
shamoo's Avatar
Default Re: this is dumb...how to bleed coolant? (dpetro1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 &raquo;</TD></TR><TR><TD CLASS="quote">the lower rad hose will get hot and then eventaully the fan will kick on </TD></TR></TABLE>
Correct, also the level of the coolant in the radiator that you just filled will drop until you can't see it anymore. The coolant is now being pumped by the water pump through the motor/heater core. You will also see the temperature gauge go a little colder suddenly.
Old Sep 19, 2005 | 04:40 PM
Shoobie's Avatar
Cool, thanks guys!
Old Sep 19, 2005 | 07:23 PM
dpetro1's Avatar
hey shamoo should the heater be on when bleeding the system?
91civicsikid
13
Jun 24, 2014 03:23 PM
95dc2teg
Sep 24, 2007 08:15 PM
hondachris1994
Mar 21, 2006 11:13 PM
Chillinit
Jun 9, 2004 08:16 AM
mz3bo
Feb 18, 2003 02:02 PM
