Could a brake booster check valve affect a boost gauge????
Old Sep 19, 2005 | 01:35 PM
DeDonDeRosa's Avatar
Default Could a brake booster check valve affect a boost gauge????
like i said in the topic if the check valve is going bad in the brake booster line could it affect the boost gauge like not make it read enough vaccuum cause my boost gauge is reading like -17 at a stop in idle but when im driving and let off the gas in gear it goes to -20 shouldnt it be -20 even at idle not -17???
Old Sep 19, 2005 | 03:05 PM
Laserjock's Avatar
Default Re: Could a brake booster check valve affect a boost gauge???? (DeDonDeRosa)
I assume you tapped the brake booster line before the check valve. I was running my vac lines this weekend and almost cut my check valve in half. duh!
Your reading more vac with the car in gear and no throttle input and coasting because the throttle plate is closed, the engine is still going thru it's normal compression stages and so it's gotta pull that air from somewhere. Big rigs use that to help stop and slow when going down hills.
Your vac readings are actually low in gear and decelerating.
Old Sep 19, 2005 | 04:05 PM
Default Re: Could a brake booster check valve affect a boost gauge???? (Laserjock)
well actually my gauge is hooked up directly to my intake manifold i didnt tap into that big line
just dont know why my gauge is acting very slow and is only reading -17 at a stand still at idle sooo
it just goes into boost then back to vac just slowly not super fast like normal
yzrider250
Aug 1, 2013 03:22 AM
lurkin' eg
Oct 19, 2008 04:28 AM
soontobeboost
Dec 5, 2005 10:00 AM
97dc2
Jul 21, 2005 10:47 AM
Boosted2K
Aug 21, 2004 12:33 PM
