Fuel management
Old Sep 18, 2005 | 06:04 PM
AZNracerx1989's Avatar
Default Fuel management
When using FMU for turbo, do you need a fuel pump?
Old Sep 18, 2005 | 06:13 PM
Lauj87's Avatar
depends.....how much boost....how big your injectors are and other stuff too...but if its a small turbo and not boosting much i would say no need.
Old Sep 18, 2005 | 06:20 PM
Default Re: Fuel management (AZNracerx1989)
stock injectors... 4.5 psi t3
Old Sep 18, 2005 | 06:23 PM
Lauj87's Avatar
stock pump will do you just fine....no need to worrie about it untill you start pushing more boost...9-15 psi is when you should start worring about more fule.
Old Sep 18, 2005 | 06:34 PM
how much would u recommened boosting max for my setup?
stock injectors
12:1 FMU
stock internals
T3 turbonetics
stock pump
Old Sep 18, 2005 | 06:45 PM
Lauj87's Avatar
is this a LS or GSR?
Old Sep 18, 2005 | 06:57 PM
.one lane's Avatar
.likes trains
maybe consider a inline pump?
Old Sep 18, 2005 | 08:16 PM
SuzukaBlueAP2's Avatar
Default Re: (Mr. One Lane)
I would not trust the stock fuel pump in a force induction setup myself. Fuel pumps are inexpensive and a piece of cake to install.
Purcahse atleast a 190 liter per hour in-tank fuel pump. YOu'll thank yourself later down the road. You want your FI setup to run a little on the rich side anyways. No lean mixtures at all. That is a no-no.
How much power do you think you're going to make at 4.5 psi? That matters more than the actual amount of boost you're putting through the engine.
Old Sep 18, 2005 | 08:21 PM
this is LS...
4.5 psi feels decently powerful for me... i just dont know how much booost to higher so i stay low to be safe
thanh4o8
Feb 6, 2009 10:53 AM
AZNracerx1989
Sep 23, 2005 11:28 AM
Teg4e
Mar 26, 2003 08:17 PM
red civic standard
Oct 10, 2002 07:47 AM
DJ0820
Aug 1, 2002 11:56 AM
