upgraded axles opinions
Old Sep 18, 2005 | 09:41 AM
slackerEG's Avatar
Default upgraded axles opinions
Looking for recommendations on axles that can handle 300-400hp and slicks without me having to worry about them breaking. I have looked at stage 2 setups from both hasport and DSS but want some opinions from people with experience. This is a budget build so I don’t want to get anything real expensive but I don’t want to snap axles all the time. The will be used on a 93 HB with a gsr.
EDIT Never mind search is working again and found my answer
Modified by slackerEG at 11:15 AM 9/18/2005
Old Sep 18, 2005 | 07:41 PM
vaporboy12's Avatar
Default Re: upgraded axles opinions (slackerEG)
gator makes pretty good axles but so does dss
Old Sep 18, 2005 | 09:10 PM
earl's Avatar
DSS is the way to go
Old Sep 18, 2005 | 09:27 PM
vaporboy12's Avatar
Default Re: upgraded axles opinions (earl)
i love my gator stage 2's no problems with 60 passes on them
hondaxsimike's Avatar
DSS gets my vote BUT keep in mind that most aftermarket axles made for racing DONT come with a warranty because theyre used for racing. to me thats a lot of money to waste for no warranty. i personally like the autozone special cuz no matter how many times i break em i can always get another for free
Old Sep 18, 2005 | 09:58 PM
kine462's Avatar
Default Re: upgraded axles opinions (hondaxsimike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaxsimike &raquo;</TD></TR><TR><TD CLASS="quote">DSS gets my vote BUT keep in mind that most aftermarket axles made for racing DONT come with a warranty because theyre used for racing. to me thats a lot of money to waste for no warranty. i personally like the autozone special cuz no matter how many times i break em i can always get another for free</TD></TR></TABLE>
People have run 10's on stock axles and maybe even faster than that. I agree with
hondaxsimike
Old Sep 18, 2005 | 11:18 PM
WillieWillieFast's Avatar
Default Re: upgraded axles opinions (kine462)
Gator
Old Sep 19, 2005 | 06:57 AM
EG_H2B's Avatar
Default Re: upgraded axles opinions (WillieWillieFast)
check out this months D-Sport mag. there is a whole article on them.
Old Sep 19, 2005 | 03:24 PM
jpenman50's Avatar
Default Re: upgraded axles opinions (JohnShiwota)
Why are you having to upgrade the axles for that amount of horsepower. Pre load the axle correctly and the chances of breaking them are going to be slim... I know of people that have ran complete seasons on factory axles w/ 600 whp plus.. But if you are in need of performance axles the best way to go is the Drive Shaft Shop. Make sure that you go with stage 5 (bigger than you need for 300-400 whp), this will allow you to move up into them and you wont limit yourself... As for gator, people have good luck with them also... They only offer there axles in a stock hub setup though....
Old Sep 19, 2005 | 10:02 PM
slackerEG's Avatar
Default Re: upgraded axles opinions (jpenman50)
Thanks for all the input. I am starting to order parts to hopefully have the car ready for next year. I am on a tight budget and was making sure I would not have to do something twice. During my search I found many people using stock axles going faster then my current goals so I am going to use the stock ones until they break.
Old Sep 19, 2005 | 10:29 PM
ninesecrx's Avatar
Drive Shaft Shop gets my vote!
Old Sep 19, 2005 | 11:32 PM
CiViC SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jpenman50 &raquo;</TD></TR><TR><TD CLASS="quote">Why are you having to upgrade the axles for that amount of horsepower. Pre load the axle correctly and the chances of breaking them are going to be slim... I know of people that have ran complete seasons on factory axles w/ 600 whp plus.. But if you are in need of performance axles the best way to go is the Drive Shaft Shop. Make sure that you go with stage 5 (bigger than you need for 300-400 whp), this will allow you to move up into them and you wont limit yourself... As for gator, people have good luck with them also... They only offer there axles in a stock hub setup though....</TD></TR></TABLE>
agree
Old Sep 20, 2005 | 04:33 AM
deftones0817's Avatar
Default Re: upgraded axles opinions (CiViC SiR)
pep boys axles. I know they arent an upgrade but my one set has lasted 3 engines. I run 24.5 inch slicks and I'm making over 400 hp
EJ8 GSR-T
30
Jul 28, 2008 06:18 PM
OG undercover
Dec 16, 2006 06:22 AM
OEMJDM
Nov 26, 2006 04:00 PM
94PearlWhiteGsr
Jul 13, 2005 06:20 PM
hybrid901
May 23, 2002 06:28 AM
