DIY: alxe replacement?
Old Sep 18, 2005 | 03:59 AM
peshte's Avatar
Default DIY: alxe replacement?
*searched*
i wana replace my axle tomorrow, and i dont know where to start...help a brotha' out
Old Sep 18, 2005 | 04:46 AM
EnzoSpeed's Avatar
Default Re: DIY: alxe replacement? (peshte)
I pull axles all the ******* time. It takes like ten minutes.
Step 1: Car on jackstands
Step 2: Drain tranny fluid
Step 3: Remove wheel
Step 4: Remove thru-bolt that attaches shock to control arm
Step 5: Un-stake and remove axle nut (impact gun needed)
Step 6: Un-pin and remove castle nut on ball joint
Step 7: Pop ball joint (do a search on this)
Step 8: Remove axle (you may need to put a prybar in between the axle and tranny to wiggle the axle out)
So that makes a total of three whole bolts. Not hard by any means.
Old Sep 18, 2005 | 05:04 AM
peshte's Avatar
Default Re: DIY: alxe replacement? (EnzoSpeed)
where do u get an impact gun?...why do u have to drain the tranny fluid?...and where is that? is it like draning the oil? lol
how long do u think it will take? keep in minde its my 1st time...
thanks alot.
Old Sep 18, 2005 | 07:45 AM
B20TDC2's Avatar
do you have an air compressor?
you will need a 32mm inoact socket. get it at autoparts store
you can get an impact at sears or harbor freight.
you do not have to drain the tranny fluid.
Old Sep 18, 2005 | 08:31 AM
dfoxengr's Avatar
ive never drained tranny fluid....
Old Sep 18, 2005 | 09:47 AM
03ephatch's Avatar
Default Re: DIY: alxe replacement? (dfoxengr)
tranny fluid change is as easy as the oil change. instead you feed the oil with a pump.
my first time doing the axle change is with the help of my friend. always have a buddy who is at least semi-mechanically inclined. took us an hour to figure everything out. trying to do it step by step. just try and do it at your pace. i'm sure your not trying to beat a world record
Old Sep 18, 2005 | 12:57 PM
peshte's Avatar
Default Re: DIY: alxe replacement? (03ephatch)
sell me a Alxe!
Old Sep 29, 2005 | 12:45 PM
rice a roni's Avatar
you dont need to drain the tranny fluid as only a little will come out when you pull hte axles out. and its fairly simple.
Old Sep 29, 2005 | 02:33 PM
Crazydave's Avatar
Default Re: DIY: alxe replacement? (2slow4u)
Don't drain the tranny fluid.
You will need a good impact gun or a good air compressor.
I had to pump mine up to 140 psi before the nut would come off
btw it's takes longer than 10 minutes if you are working at home.
5-10 minutes to find all the tools you need an turn on the air compressor
5 minutes to jack the car up and put it on stands, and take the wheels off.
30 seconds to try to take off the shock fork bolt.
30 seconds to realize you need a short impact socket or a universal joint
1 minutes to find the correct impact joint or shorty
5 seconds to realize you need a wrench on the nut on the other side.
1 minute to get up off the ground and find the wrench
20 seconds to 1 hours to **** and moan about the axle nut and wait for the compressor to pump up some more and try squirting WD40 all over the nut.
5 minutes to get on honda-tech to find alternatives to removing axle nut
30 minutes to post & read posts of a "GODAMN AXLE NUT WON'T COME OFF THREAD"
2 minutes to wack the hell out of the lower ball joint
2 minutes to remove axles
1 minutes to get up and get new axles
1 minute to get tranny side in,
5-10 minutes to line up splines on hub side
15 minutes to bolt everything back up put the tire on and put the car back on the ground.
Bottom line expect at LEAST 30 minutes a side for axle install, but it could take longer
BTW.... DONT USE A 32mm 12 point chrome socket. IT WONT WORK. you need a 32mm 6 point IMPACT SOCKET
Modified by Crazydave at 4:57 PM 9/30/2005
Old Sep 30, 2005 | 11:40 AM
Default Re: DIY: alxe replacement? (Crazydave)
y would u use a chrome socket on an impact gun? thats just plain stupid...they are made to do their job...impact socket goes on an impact gun...
Old Sep 30, 2005 | 12:26 PM
boost93's Avatar
you don't need an impact gun, use a breaker bar
Old Sep 30, 2005 | 01:07 PM
Burke's Avatar
Banned
Default Re: (boost93)
if you dont have air, break the axle nut loose while the car is still on the ground. depending on your wheels, it should be right there. get a breaker bar and hop on it. wahlaa
for the ball joint, you are gonna need a ball joint splitter OR hit it REALLY F'N HARD on the side of the hub or lca and it will eventually pop off
Old Sep 30, 2005 | 06:36 PM
Default Re: (Burke)
no..a ball joint splitter destroys your ball joint and you'll need a new one. didnt anybody teach you the double hammer technique?? i'll teach all of you for 5 bux each...it'll save tons of headaches and cash....................
just kidding...
heres how you do it.
to get the lower ball joint to pop out take off the bolt that holds the fork to the lower control arm so that the lower control arm can swing down freely.
take off the castle nut that has a cotter pin in it and of course...you take out the cotter pin out first...duh
when you get the nut off thread it back on just a tad bit so the lower control arm doesnt fly off when you knock it loose.
now you'll need two hammers. one goes on each side of the ball joint. you might need a buddy for this so yeah...grab your sister, brother, friend, **** buddy, dad, mom, grandma, or grampa...yeah you get the idea. All they need to do is hold one hammer up to the ball joint so that when you whail on the other side their hammer bounces away. have them hold it there while you hit it and it should pop out..trust me, it works wonders. if not, keep going until you knock it loose...
the other way is to use a pickle fork and stick it between the ball joint and lower control arm then hit the end of that with a hammer, but i'd only recommend this if you're replacing the worn out ball joint...well, try it and have fun...this technique has saved me tons of time and money...
Old Sep 30, 2005 | 11:12 PM
EnzoSpeed's Avatar
Default Re: (2slow4u)
You guys are lame. Here's how you pop a ball joint:
1. Jack the wheel up as high as it will go.
2. Place a 1/2" rachet handle between the control arm and steering knuckle.
3. Remove the jack and let the wheel back down.
That's it. No hitting anything with hammers, no special tools, and no ripped boots. Plus it takes less than a minute to do.
For a good explanation of how this method works, do a search.
Old Oct 1, 2005 | 05:41 AM
Default Re: (EnzoSpeed)
For a good explanation of how this method works, do a search.[/QUOTE]
but you CAN break a tool...ha...putting a tool in between and letting it go...i dont think most sae certified techs would like that much. and its not professional.
Old Oct 1, 2005 | 02:03 PM
EnzoSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2slow4u &raquo;</TD></TR><TR><TD CLASS="quote">
but you CAN break a tool...ha...putting a tool in between and letting it go...i dont think most sae certified techs would like that much. and its not professional. </TD></TR></TABLE>
How do you break a rachet handle??? Trust me, this method is full-proof.
Old Oct 2, 2005 | 05:13 AM
anything can break man...trust me.
Old Oct 2, 2005 | 05:20 PM
EnzoSpeed's Avatar
Lol, YOU CAN'T BREAK A PIECE OF SOLID STEEL BY PINCHING IT! Trust me, this is the method that everyone uses, even Honda techs.
Old Oct 2, 2005 | 07:33 PM
tru_pimp's Avatar
you can break it. i know becaus eit happens at work. and it aint cool because you have to buy another one off the tool truck.
Old Oct 2, 2005 | 08:00 PM
EnzoSpeed's Avatar
Default Re: (tru_pimp)
It's not physically possible guys. Either you're doing something terribly wrong, or we're talking about different things here.
Old Oct 3, 2005 | 04:18 AM
i dunno man, i just dont want to risk breaking a 50 dollar or more tool just trying to pop out a balljoint..and i think it'll take longer then my double hammer method.
Old Oct 3, 2005 | 07:27 AM
Crazydave's Avatar
You don't even need the use the double hammer method. just get one big *** hammer, and give it a good strong whack.
Old Oct 3, 2005 | 08:37 AM
tyro's Avatar
Default Re: (Crazydave)
These also work well for separating ball joints; cheap too:
Old Oct 3, 2005 | 10:07 AM
lol, thats the old way of doing it...but you usually end up bending things.
joker4268
Oct 5, 2007 02:35 AM
crx18c1
10
Apr 17, 2007 10:17 PM
EFin' Kyle
Dec 13, 2005 10:29 PM
Immanuel
Oct 2, 2005 12:47 PM
homesauce
Mar 25, 2005 11:15 PM
