Transmission Questions
Old Sep 17, 2005 | 07:24 PM
b18bEKcoupe's Avatar
Default Transmission Question
My brother has recently started having some grinding issues in his tranny. I was wondering how difficult is it to replace the synchros in a d series tranny and if its even worth it. I wish i would have saved my Y8 tranny from my swap but its too late for that. I think it might be time to look for a new tranny but if its not too big of a job we will just rebuild the one he has.
Modified by b18bEKcoupe at 7:34 PM 9/19/2005
Modified by b18bEKcoupe at 7:35 PM 9/19/2005
Old Sep 17, 2005 | 09:54 PM
Default Re: Transmission Questions (b18bEKcoupe)
BUMP
Old Sep 21, 2005 | 12:39 PM
SOHCD16y8's Avatar
How old is the clutch? sometimes when the clutch gets old it doesnt want to release all the way and causes a grind. I would also try some syncromesh trans fluid also. It fixed my buddies 3rd gear grind in his teg.
Old Sep 21, 2005 | 12:48 PM
Crazydave's Avatar
Default Re: (SOHCD16y8)
also check this post
http://www.d-series.org/forums...19200
rebuild run $700+
used trannys depending run $150 - $400
Old Sep 22, 2005 | 06:58 PM
mrlegoman's Avatar
Default Re: (Crazydave)
I had the same issues and it turned out to be a bad clutch.
Is it one gear in perticular or all of them?
Old Sep 23, 2005 | 10:45 PM
purejdmsi's Avatar
Default Re: (mrlegoman)
d series trannys are cheap try to get a d16z6 tranny shorter gears
slix_eg
May 10, 2007 03:39 PM
reeder321
12
Dec 31, 2003 07:29 AM
Proper
Apr 23, 2003 04:55 PM
Fr0m4311
Apr 7, 2002 09:31 PM
phatintegra
12
Mar 20, 2002 05:37 PM
