Tueno spewing oil all over the place.......Help maybe seals or turbo
Old Sep 16, 2005 | 05:37 PM
DRKSol's Avatar
Default Turbo spewing oil all over the place.......Help maybe seals or turbo
I have a t3 67 trim turbo and the other cday i thought that the drain was wrong so i changed it around but the same thing the turbo spews oil all over my block. what could that be and how bad could it be? it has only done it twice or three times....the other day when i chamged my oil it took 5 qts of oil to fill but the type r pan is like 4 qts.. could that be some of the problem?
Old Sep 16, 2005 | 05:42 PM
88_DX's Avatar
Default Re: Turbo spewing oil all over the place.......Help maybe seals or turbo (jh)
Do you have the wronge dip stick? or not check your oil on level ground?
Old Sep 16, 2005 | 05:43 PM
DRKSol's Avatar
Default Re: Turbo spewing oil all over the place.......Help maybe seals or turbo (88_DX)
i did it in the shop and i put 4 qts in and started teh car to run the oil throughout the motor and it was low so added more....its my first turboed car so i figured it was the turbo.. any help?
Old Sep 16, 2005 | 08:49 PM
Redwidow's Avatar
you might have to much oil and its not draining back properly... Did you add oil and check it while it wa running?
Old Sep 17, 2005 | 10:59 AM
yee SERIOUS's Avatar
i had a problem kind of the same. no sealant on my oil pan! so i took it off and threw some sealant on there.
Old Sep 17, 2005 | 02:35 PM
DRKSol's Avatar
Default Re:
i drained the oil today where i had only engouh but the turbo still spew oil..
ITS_Dunn
Mar 16, 2006 04:51 AM
Cee_mon
Nov 18, 2005 06:11 AM
CRXdan
Apr 4, 2005 06:28 PM
71 mgb
Nov 12, 2003 10:49 AM
Yamzz_EG
May 18, 2003 11:38 PM
