LS compression 160? ok?
I did a compression test on my 98 Ls teg with 114,164 miles on it and I am 160 across the board. Is this good. I am told this is low for an Ls. If so could I slap in some ITR pistons with no prob? Or will I have valve problems?
160 psi on a LS isn't great, but still within Acura specs, 185 nominal, 135 minimum, with max variance of 28 psi, at least for my 92 RS B18a those are the specs from the Helms manual.
