How do you troubleshoot ignition system
Old Sep 15, 2005 | 09:17 PM
elpiar's Avatar
Default How do you troubleshoot ignition system
I have bad mpg and tried all kinds of stuff. This is on my list.
How should I backtrack the problem (if any) anyone got a checklist?
Obviously I changed the spark plug and sparkplug wires, distributor cap and rotor.
Old Sep 15, 2005 | 09:20 PM
Kendall's Avatar
Check the ignition timing and then change the fuel filter before you do anything else.
Old Sep 15, 2005 | 09:32 PM
elpiar's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Check the ignition timing and then change the fuel filter before you do anything else.</TD></TR></TABLE>
Done it already.
Old Sep 15, 2005 | 09:34 PM
Lauj87's Avatar
try replace fule filter..air filter?....you know if your running to rich? could be the problem..
Old Sep 15, 2005 | 09:37 PM
elpiar's Avatar
Default Re: (Lauj87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lauj87 &raquo;</TD></TR><TR><TD CLASS="quote">try replace fule filter..air filter?....you know if your running to rich? could be the problem..</TD></TR></TABLE>
Did both fuel filter and air filter, tuned to 14.7 except for WOT (open loop)
Old Sep 15, 2005 | 09:39 PM
Lauj87's Avatar
what kinda mods you have on it?
Old Sep 16, 2005 | 05:39 AM
Sam92Teg's Avatar
Make sure you didn't jump time, meaning your cam gears and crank pulley are in the proper alignment and your timing is correct. Then have your coil and ignitor in the distributor checked. Also make sure your cat conv isnt clogged or failing.
Old Sep 16, 2005 | 06:09 AM
BlackLudeSi's Avatar
Default Re: (Sam92Teg)
O2 sensor? Is that new i've seen cars get horrible mpg because of bad O2 sensors
jhony_ej6
Jul 11, 2008 09:55 AM
erottik-R
Sep 15, 2006 11:03 AM
mtownsi
Jun 3, 2006 07:14 PM
jDm_jeremy
Nov 18, 2005 04:32 AM
-16V-
Mar 20, 2004 05:16 AM
