I guess I need a camber kit :(
Old Feb 28, 2002 | 07:03 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default I guess I need a camber kit :(
I was hoping to get away without one, but the alignment rack this morning showed I had -2.1 degrees left and -2.4 degrees right camber. The guy set the toe for me on all 4 wheels and only charged my $20 (this was at 7 a.m., they weren't busy), but I guess I'll have to shell out the money for a camber kit and put it on, then bring it back to them.
Old Feb 28, 2002 | 07:05 AM
madchiller's Avatar
Premium Member
25 Year Member
Default Re: I guess I need a camber kit :( (PatrickGSR94)
ingalls extreme kit for around $200 isnt too bad for the peace of mind that you will not have to buy tires every 2 months! installation isnt too bad either.
Old Feb 28, 2002 | 08:19 AM
Community Builder
Default Re: I guess I need a camber kit :( (FuknGSR)
Well I don't think i will be buying tires every 2 months, with regular rotation. I would like to have about 1 to 1.5 deg. camber, which I think a regular camber kit should be able to correct. It's just extra money for the parts and the time and adjustments that I was hoping to avoid.
Old Feb 28, 2002 | 08:25 AM
98SILVERGSR's Avatar
From: I want a 3some with Chasey Lane and Jenna Jameson, Canada
What drop do you have for this sort of camber?
Old Feb 28, 2002 | 08:28 AM
Community Builder
Default Re: I guess I need a camber kit :( (98SILVERGSR)
H&R Sport, supposedly 1.75 in front (I didn't measure before installing), but my car is pretty low, only 1-finger gap in front.
Old Feb 28, 2002 | 08:39 AM
neo1z's Avatar
yea my tire wear is bad on my h&r's -- its depressing, my new kumhos are wearing down. i need a camber kit badly.
Old Feb 28, 2002 | 08:46 AM
MileHiGSR's Avatar
I have the same springs with Tokico Blues and 17" wheels, 205/40/17 tires. I think I have less fender clearance than you. It definitely looks like more than a 1.75" f and 1.5" r drop. Supposedly my Tokicos drop my car another .5" or so, but I can't verify that for sure. I haven't measured my camber, but I suspect I'm in the same situation as you. I wouldn't mind except camber kits for this car are so damn expensive. Oh well. How are the Konis? Good, I assume, from the .
Old Feb 28, 2002 | 08:58 AM
Vazquez911's Avatar
Hehe, you thought you could go that low and get away with it!
Premature tire wear stinks... but MAN it helps handling if the camber is dialed in right.
Old Feb 28, 2002 | 10:01 AM
Community Builder
Default Re: I guess I need a camber kit :( (MileHiGSR)
Tokico shocks won't change your ride height. I have the spring perches on my Konis set at stock for the front, and on the lower perch in back, so it's probably closer to a 2" drop in back (went from almost 4-finger gap to less than 1 in back). I'll tell ya tho, the car looks awesome and handles great.
Old Feb 28, 2002 | 10:28 AM
ALF's Avatar
ALF
Sorry to hear about your camber woes. How is the camber in the rear? Perhaps you can get away with it with regular tire rotations...
Old Feb 28, 2002 | 11:02 AM
BSQ's Avatar
BSQ
Here is a "no cost solution"...raise the spring perches on the Konis. This will raise the ride height slightly and it will correct your camber. It may not "look" as nice, but it will save you $200 and it will handle the same.
Old Feb 28, 2002 | 11:30 AM
A-dub5513's Avatar
Default Re: I guess I need a camber kit :( (BSQ)
Been looking through old threads and I'm seeing that a lot of you with Konis(yellows) are setting your front perches higher than your rear. I'm not sure I understand because from my experience, with Sportlines at least, the back tends to sit lower than the front (sag).
This was evident with Tokico blues in my previous cars as well as everyone I knew that had Sportlines. I am currently using RS*R race springs (average 2.2" drop!!) with "yellows" and have finally decided to raise the ride height for longer lasting tires as well.
So the question is: Am I correct, in theory, about the idea of raising the rear one perch higher with Sportlines? Or H&R Sports would be a better spring to go with altogether? I know everyone's got an opinion. Just wanna get all the fact beforehand because I were just about to whip out the charge card. Thanks!
Old Feb 28, 2002 | 04:49 PM
Community Builder
Default Re: I guess I need a camber kit :( (A-dub5513)
The front shocks are on the top perch already. The rears only have about 1 or 1.5 neg. camber w/ the perches on the bottom setting, if I read the computer screen in front of the alignment rack correctly. Before I lowered the car, and after I lowered it w/ the perches all at stock positions, my car sat higher in back than in front, so putting the rears on the lower setting evened it out very nicely.
pr0phet
Nov 22, 2005 03:59 PM
TegoDC5
15
Oct 20, 2004 10:01 AM
DC4 teg
Dec 17, 2003 04:17 PM
tr4il
Nov 23, 2001 10:14 AM
