why cant you hook a autometer a/f gauge to a wideband o2?
Old Sep 15, 2005 | 02:52 PM
hondaguyexsi's Avatar
Default why cant you hook a autometer a/f gauge to a wideband o2?
why cant you hook a autometer a/f gauge to a wideband o2? like to know why this is.
Old Sep 15, 2005 | 03:07 PM
non-VTEC's Avatar
Default Re: why cant you hook a autometer a/f gauge to a wideband o2? (hondaguyexsi)
the autometer a/f gauge operates from 0 to 1 volt for the signal input.
at typical widband sensor operates from 0 to 3.5 volts or sometimes more depending on the sensor.
it will not work period.
Old Sep 15, 2005 | 03:21 PM
Default Re: why cant you hook a autometer a/f gauge to a wideband o2? (non-VTEC)
how do you know if its a wideband sensor
Old Sep 15, 2005 | 03:48 PM
non-VTEC's Avatar
most if not all honda's use normal narrow band o2 sensors (0-1volt)
Old Sep 15, 2005 | 04:46 PM
how many wires
Old Sep 15, 2005 | 04:47 PM
mine is a denso 4 wire
Old Sep 15, 2005 | 04:58 PM
ScottEK's Avatar
Wideband sensor dont output the voltage themselves either you need a controller box, some controller boxes however do output 0-1v but who the hell wants to guess if a green light means they have the right AFR.
Old Sep 15, 2005 | 05:33 PM
Default Re: why cant you hook a autometer a/f gauge to a wideband o2? (ScottEK)
so there not accurate
what should i use
Old Sep 15, 2005 | 09:29 PM
Muckman's Avatar
Moderator in Chief
Good widebands have a second 0-1v output that you could attach your autometer A/F gauge too. It wouldnt have as much resolution as the full 5v output tho.
Old Sep 16, 2005 | 04:49 AM
Default Re: why cant you hook a autometer a/f gauge to a wideband o2? (Muckman)
resolution. do these gauges serve a purpose or not. i just wann know if the close. im getting my car tuned anyways but i just wann know if my car leans out.
Old Sep 16, 2005 | 07:10 AM
Buzzbomb's Avatar
For tuning purposes, no they do not serve a purpose. Example:
Let's say you're in boost, and your AFR is 13.5:1 On a narrowband A/F gauge, this is going to show rich as pretty green LED's. When in fact, you are too lean for boost and will blow up.
The narrowband gauge pretty much just shows you when you are in closed loop or open loop.
Old Sep 16, 2005 | 10:35 AM
tgreaves's Avatar
Default Re: why cant you hook a autometer a/f gauge to a wideband o2? (Buzzbomb)
Those gauges are just little light displays.. And a wideband sensor is nothing, its the controller box for the sensor that does everything..
Old Sep 16, 2005 | 11:32 AM
Default Re: why cant you hook a autometer a/f gauge to a wideband o2? (tgreaves)
so should i get tuned and not worry about it, or is there a possibility for the tune to change
Old Sep 16, 2005 | 12:01 PM
Buzzbomb's Avatar
The AF ratio varies the most with temperature changes. Most editing software out is now including correction for this, but other things can change it as well.
Personally, I'd get a wideband so you can keep an eye on what AFR is at all times so if it starts to get too lean or too rich you'll catch it before you do any damage.
You don't HAVE to, but most here would recommend it.
Old Sep 16, 2005 | 06:35 PM
im running uberdata so does this mean ill have to keep retuning or should i use something different
Old Sep 21, 2005 | 01:02 PM
does the air fuel ratio on the apexi turbo timer work well, is it close to a wideband?
Old Sep 21, 2005 | 01:06 PM
tgreaves's Avatar
The only thing close to wideband is wideband.. There is narrowband and wideband.. Any narrowband no matter the company cannot be used for tuning at all..
Old Sep 22, 2005 | 05:13 AM
Buzzbomb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyexsi &raquo;</TD></TR><TR><TD CLASS="quote">im running uberdata so does this mean ill have to keep retuning or should i use something different</TD></TR></TABLE>
Uber has temperature change correction in it, so it the tune should remain the same with slight fluctuations.
Old Oct 7, 2005 | 01:52 PM
boywonda's Avatar
http://www.plxdevices.com/NB_WB_GaugeConv.htm
heres a product I just found that will do what you want; but you will have to buy the wideband controller as well
Old Oct 8, 2005 | 06:11 PM
2muchboost2blow's Avatar
Default Re: why cant you hook a autometer a/f gauge to a wideband o2? (boywonda)
you could get a wideband like the plx m300, and hook the narrowband output up to the a/f gauge.
Old Oct 8, 2005 | 06:58 PM
h22 civic's Avatar
Default Re: why cant you hook a autometer a/f gauge to a wideband o2? (2muchboost2blow)
their was some one that moded the autometer a/f gauge to read from 5v to 1v
nytosc
Aug 23, 2008 07:40 AM
madman604
Oct 21, 2003 07:11 PM
photonjedi808
25
Apr 17, 2003 12:08 AM
dariusz
May 8, 2002 03:13 AM
