FPR question
Old Sep 15, 2005 | 01:37 PM
zephon96's Avatar
Default FPR question
so im swapping an integra B18a1 into my 90 CRX. im looking for a fuel rail and fpr. does anybody know if the fpr and rail must come from the same car, or if the fpr must be a certain obd setup? can i use say a rail and a fpr from different operating systems? like a b17 rail and b18c fpr? thanx. --Jim
Old Sep 16, 2005 | 04:40 AM
JimBlake's Avatar
Default Re: FPR question (zephon96)
I'm sure there's a bunch that would work. But B18C has higher fuel pressure than B18A, so you can't use that one.
I don't know the whole list of what's compatible with what else. You need 2 things...
The FPR has to physically screw into the rail (duh).
The fuel pressure has to be correct.
Old Sep 16, 2005 | 01:25 PM
zephon96's Avatar
Default Re: FPR question (JimBlake)
Ok, that makes sense. Any idea where I could go/look to get some more info on the subject?
Old Sep 16, 2005 | 02:27 PM
SockEG's Avatar
if you buy an adjustable FPR, then all you have to do is make sure it mounts to the rail. and get yourself a fuel pressure gauge and mount it at your fuel filter. and adjust it to the factory spec.
got-vtec?
Oct 16, 2011 10:08 AM
zCivic
Sep 7, 2006 02:42 PM
kim_2_da_chee
Feb 8, 2006 09:44 AM
Blown90hatcH
Jun 22, 2003 07:27 PM
nema741
Apr 23, 2003 07:26 AM
