Aeromotive FPR Q?
Aeromotive FPR Q?
Quick Q? I have the aeromotive FPR finishing up my fuel system install. My question here is can I thread my fuel pressure sending unit for my fuel pressure gauge into the front port on the FPR? I have the fuel line on the side and the return on the bottom.
Thanks, JAson
Thanks, JAson
Re: Aeromotive FPR Q? (Blown90hatcH)
isn't there already a port on the front side of the FPR ? there is no hole on the back since the bracket goes there.
You can drill and tap on any side as long as it stays on the bottom half the the FPR and you can tap fuel rpessure from there
stan
stan
Re: Aeromotive FPR Q? (Flamenco-T)
There should be a port on the front of the FPR where you can screw in the sending unit or a fuel press. guage. What kind of fuel rail are you using? It'll be better to tap it at the rail instead of having it hanging off the FPR.
Re: Aeromotive FPR Q? (boostaholic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostaholic »</TD></TR><TR><TD CLASS="quote">There should be a port on the front of the FPR where you can screw in the sending unit or a fuel press. guage. What kind of fuel rail are you using? It'll be better to tap it at the rail instead of having it hanging off the FPR.</TD></TR></TABLE>
I have the AEM rail.....so you think just screw it into the rail instead of the regulator? I will check that out in the morning thanks. Also, I will need to just plug the hole in the front of the regulator I suppose.
Jason
Jason
Thanks Stan the man. I have a few laying around. I have been building this car for so long I have forgotten too many things. Hopefully....drive it this week.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostaholic »</TD></TR><TR><TD CLASS="quote">Yeah Jason, just screw the sending unit into the rail and use a 1/8" npt plug on the front port of the fpr.</TD></TR></TABLE>
Thanks alot guys.
Thanks alot guys.
prodragEG
Northwest (Sales)
09-19-2008 12:50 PM
