4dr DA door panels on 2dr
Will the front door panles from a 4dr DA fit in a 2dr DA?? Reason im asking is cuz i am converting mt 2dr DA to power windows and locks, and the glass,regulators,door panles are from a 4dr DA.
Also what all would i need to convert my DA to power windows and locks?
Glass
Regulators
door panels
switches
Wiring harness from both doors
Anything else??
Glass
Regulators
door panels
switches
Anything else??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4sd4dr »</TD></TR><TR><TD CLASS="quote">no, the panels will not fit.
you dont need the glass to convert to power windows.
its going to be a PITA</TD></TR></TABLE>
or he could get the power doors from another 4 door model
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4sd4dr »</TD></TR><TR><TD CLASS="quote">well, he has a 2 door. what good would sedan doors do on a coupe?</TD></TR></TABLE>
then he could get doors from a 2 door with the power components
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4sd4dr »</TD></TR><TR><TD CLASS="quote">yea, but the car itself doesnt have the pw wiring... agian, it'll be a PITA.</TD></TR></TABLE>
true, but it would be much easier to have the whole door and just bolt that on and wire it up then picking apart his door and piecing the **** together
From: Good luck to this industry, you're gonna need it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp »</TD></TR><TR><TD CLASS="quote">
true, but it would be much easier to have the whole door and just bolt that on and wire it up then picking apart his door and piecing the **** together </TD></TR></TABLE>
I'd almost agree....get the doors and the corresponding wiring and relays...and YES IT WILL BE A PAIN IN THE ***
Im buying the wiring harnees out of a DA door that has PW.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdM DA InTeGrA »</TD></TR><TR><TD CLASS="quote">
Im buying the wiring harnees out of a DA door that has PW.</TD></TR></TABLE>
that does not reduce the PITAness, changing a dash harness is tedious and tiresome work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdM DA InTeGrA »</TD></TR><TR><TD CLASS="quote">Y would i have to change the dash harness?</TD></TR></TABLE>
HAHAHAHA because wiring power windows and PDL is not just as easy as you think it is (unless you are using an aftermarket kit).......if you want it like stock, out comes the dash harness
da9kid11
Oct 6, 2008 06:39 PM
Filliam H. Muffman
Sep 16, 2003 12:10 AM
