Heat protective Hose? Hose is near exhaust housing...
I used heater hose to run my water lines on my turbo however with one of the lines, it's real close to the exhaust housing and it's got me worried. Is there anything I can use to protect the hose from the heat? Any recommendations?
Modified by BigMoneyP at 8:59 PM 9/14/2005
try this...
http://www.thermotec.com/produ....html
all of the turbo set ups i've seen on honda motors don't require the coolant line's being hooked up. usually they're just plugged.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jayswift »</TD></TR><TR><TD CLASS="quote">all of the turbo set ups i've seen on honda motors don't require the coolant line's being hooked up. usually they're just plugged. </TD></TR></TABLE>
so all the ball bearing turbos, plug there lines
I used it on ym turbo feed line to be safe, but you cold use it on your water lines as well. Just slip it over...
http://www.bakerprecision.com/insulat.htm
I got the aluminum coloured one. It's teh fyrejacket one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoSP »</TD></TR><TR><TD CLASS="quote">trim that return line and get a 45 degree AN fitting</TD></TR></TABLE>
Is this necessary?
Is this necessary?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">all of the turbo set ups i've seen on honda motors don't require the coolant line's being hooked up. usually they're just plugged.</TD></TR></TABLE>
Its not about the motor, its about the turbo, you increase its life and oil life when you put the waterlines. If I had a watercooled turbo, I'd surely connect the waterlines too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigMoneyP »</TD></TR><TR><TD CLASS="quote">
Is this necessary?</TD></TR></TABLE>
yes
yes
WAter line fixed, i'm going to leave the drain that way till i can get my hands on a 45 degree AN fitting
I would definantly look into trimming that return line and getting a different fitting. The length of the hose seems a bit excessive, and the slight bend might not flow as well as a straight line would.
Yes. You want your return line to be as straight/downhill/and as short as possible. Any uphill direction in the line is very very bad.
-BigMoneyP-
you could just clock the center section of your turbo to where the oil return faces down instead of that 45 degree angle and then you'd be cool/better on the drain
and then you could cut a lot of that drain off and it would look much cleaner
honda_racing101
Nov 2, 2007 12:47 PM
Nisif
Aug 12, 2006 04:53 PM
Nisif
Aug 11, 2006 07:02 PM
