my car just started sputtering
Old Sep 14, 2005 | 06:33 PM
VTECdTypS's Avatar
Default my car just started sputtering
I started driving home from class in my 91 hatch and i noticed that at lower rpms when i accelerate it sputters, but once the rpms build up it runs fine. I dont have a tach in there so i dont know what the rpms are exactly but i can tell approximatly where about. Its got nearly 184k miles and it slightly burns oil but i never had any these problems with it. the distributor has been changed less than a year ago but i dont know if it was a new or used on. What could cause this sputter? i thought maybe an exhaust leak but it doesnt really sound any different.
any ideas?
Old Sep 14, 2005 | 06:44 PM
VTECdTypS's Avatar
Default Re: my car just started sputtering (VTECdTypS)
i also put in new plugs less than a year ago. I did a search and quite a few people had similar problems but i couldnt find a solution.
Old Sep 14, 2005 | 06:46 PM
ALLMOTA92EG's Avatar
Possibly your ignition timing is off.
Old Sep 14, 2005 | 08:52 PM
VTECdTypS's Avatar
Default Re: (jdm92civichb)
any other opinions guys?
Old Sep 15, 2005 | 09:42 AM
VTECdTypS's Avatar
Default Re: (VTECdTypS)
? come on people, someone has to have other opinions. This is my daily so its gotta be dependable.
Old Sep 15, 2005 | 09:51 AM
KansasKev's Avatar
Could it possibly be fuel pump?
Spark plugs fowled?
Oil in the plugs?
Old Sep 15, 2005 | 09:53 AM
boonacka's Avatar
Considering it has nearly 185k miles on it, it may need a major tuneup. This would include:
Ignition related parts ( plugs, cap, coil, rotor, wires)
Fuel system ( injector cleaner, fuel filter)
Intake system ( throttle body cleaned, PCV, valves dirty - not seating/sealing properly)
could also be caused by - bad Oxygen Sensor, Bad gas, ignition timing off, timing belt slipped, weak alternator/charging system
... theres a bunch of stuff
Old Sep 15, 2005 | 01:35 PM
VTECdTypS's Avatar
Default Re: (boonacka)
im not too familiar with the pvc valve. Where on the block is it located and how easily is it swaped out?
Old Sep 15, 2005 | 01:47 PM
91CivicHatchback's Avatar
what motor is in it??d15b? ive got the same problem but ive got a burnt exhaust valve so its a dead miss on lower rpms but 3500 and up its fine..run a compression check on it
Old Sep 16, 2005 | 04:51 AM
boonacka's Avatar
Default Re: (91CivicHatchback)
I'm leaning towards burn valve or rings are going. just lke the guy above said.. compression and leakdown test.
-=ZAK=-
19
Jan 29, 2009 06:14 PM
allshownogo
11
Feb 26, 2008 09:19 PM
Missouri_Civ
14
Aug 2, 2007 07:06 PM
smercer
Feb 9, 2005 10:12 AM
Digital-R
Aug 3, 2001 11:07 AM
