anyone w/integras.. what is this??
Old Feb 27, 2002 | 09:22 PM
fiebru1119's Avatar
Default anyone w/integras.. what is this??
when i start up the car for the first time in the day, or after it has cooled down extensively, there is a momentary mechanical/electronic noise comming form the front passengers side of the car.. kinda like a (brrrrraaaa...) it only lasts a second or two right after start up. however, yesterday it lasted alot longer (5-6 seconds) and the repeated itself for another second or two after that. what is this?! has anyone heard of such a thing? i though it was normal since it always did it, but now its doing it more. thanks
Old Feb 27, 2002 | 09:27 PM
ThePunk's Avatar
Default Re: anyone w/integras.. what is this?? (fiebru1119)
Rumor has it that that is the ABS pump priming....I don't know for sure, but my R does it too.
Old Feb 27, 2002 | 09:34 PM
3rdGteg's Avatar
Default Re: anyone w/integras.. what is this?? (ThePunk)
Check your your ABS fluid. Pretty sure that it, so fill it up and the noise should go away. I have two integras and they both have had that problem.
Old Feb 27, 2002 | 09:44 PM
fiebru1119's Avatar
Default Re: anyone w/integras.. what is this?? (3rdGteg)
thanks for the info, i'll get on that
Old Feb 28, 2002 | 11:20 AM
Shft@9GSR's Avatar
I agree with everyone on the ABS motor. Mine does it at start up and time length is variable. Sometimes it even makes noise while driving.
Old Feb 28, 2002 | 01:42 PM
Westrock2000's Avatar
Default Re: anyone w/integras.. what is this?? (Shft@9GSR)
Where do you put the fluid in....mines starting to act up and will make that grinding sound alot then the ABS light just comes on.
Old Mar 7, 2002 | 09:34 AM
3rdGteg's Avatar
Default Re: anyone w/integras.. what is this?? (Westrock2000)
Pop your hood, the abs motor is on the left handside (where your intake filter is banging against, at least on mine) there is a little grey plastic cap on top of it-- open it and refill the fluid there. The sound should go away until the fluid is low again--there must be a leak somewhere but noone knows yet.
Old Mar 7, 2002 | 09:44 AM
sgT's Avatar
sgT
A lot of times the ABS unit needs to be bled.
97+ cars have the newer ABS which shouldnt need that though,
Old Mar 7, 2002 | 11:59 AM
3rdGteg's Avatar
Default Re: anyone w/integras.. what is this?? (sgT)
I have two '96s and they both have that problem. Weird huh! Maybe there's a recall on these.
Old Mar 7, 2002 | 01:13 PM
92sleepR's Avatar
New User
ABS pump. No big deal just bleed the high pressure lines.
Mike
SL0WEGG
May 4, 2005 03:25 PM
Mike1486
Jan 17, 2005 01:20 PM
1992gsrb17
Mar 24, 2004 03:00 PM
Havokgsr
Dec 15, 2002 01:11 AM
Mr. Softee
Sep 10, 2001 05:56 PM
