t3/.67 turbo for a b16a???
Old Sep 14, 2005 | 02:51 PM
bnut510's Avatar
Default t3/.67 turbo for a b16a???
sup all, im currently using a t3/t04e turbo on my b16a and in the process of rebuilding the whole motor. i want to go for about... 500-600 hp if possible. here will be my setup...
crower rods, je pistons low comp, type r cams, some cam gears, hondata s200boost, 255 fuel pump, 1000 cc injectors, blockguard, some sort of sleeving, valve springs and retainers, valves, type r lsd tranny, bout to ditch the fmu since i heard u dont need it with hondata, ditch the missing link. and of course to be on topic.... i will be using the t3/.67 turbo. i would like to go with the gt35r no doubt. but all in all, can this be done with this setup? and hows the difference between the gt35r and the t3/.67 knowing that its not ball bearing... but besides that... hows the pull on the t3/.67?? o yeah and i think i might stick with the stock bore on the pistons. holla back with info yall!!!!
tron_
May 16, 2013 11:22 AM
Vovchandr
Jan 13, 2007 08:34 AM
TsukubaSpec
Oct 28, 2005 03:38 AM
bnut510
Sep 15, 2005 11:02 AM
The Crow
Jan 11, 2004 09:10 PM
