this is getting old
Old Sep 12, 2005 | 06:35 PM
raiden571's Avatar
Default this is getting old
ok. got the new fuel injectors today, changed the oil etc, and no longer does it sound like im getting a fuel cut off at around 3-4 k or at idle. but now i get it hard at 5k, but only in 2nd gear and up, once it gets to about 5.5k, it stops. so wtf?
tony and me are gonna do a valve adjustment this weekend and see if that clears it up.
and for you uberdata people that may know how to tune. is it possible for a chip to get corrupt? listen to this, from may thru july, the car ran perfect, never a problem. then one day, bam, the car starts showing symptoms of a fuel cut off...and so on. ive changed spark plugs, numerous times, checked my spark, checked cap, rotor, replaced fuel injectors, replaced fuel pump, new air filter, new fuel filter, have only used high octane gas. so is it possible that the chip some how got fubared??
i need some helps guys, this car is starting to get on my nerves. now i know i only have to put up with it for a few months until the new motor goes in, but i wanna have fun before the winter.
Old Sep 12, 2005 | 06:50 PM
raiden571's Avatar
Default Re: this is getting old (raiden571)
ok. ive been talking with some people. is it possible that the dizzy is junk or maybe even the VSS?
anyway to check either of them?
Old Sep 12, 2005 | 07:47 PM
Muckman's Avatar
Moderator in Chief
Try another distributor before anything else.
Old Sep 12, 2005 | 07:51 PM
redzcstandardhatch's Avatar
something different
Default Re: this is getting old (Muckman)
whats your spark plug gap? i am having a nearly identical problem....
first gear RIPS all the way up, and then once and a while in 2nd it will hit a weird "revlimiter" kinda thing, just BAM stops for a second (almost violently) and then continues running, perfectly, never hurt a thing.
it only does it sometimes (seems like when its colder)
i've had a couple very knowledgable people tell me its the plugs/gap.
it ran great on the plugs for a while, been on them a year or so. then, all the sudden, it seems to be blowing out the spark, we'll see.. fixing it this weekend, or trying.
Old Sep 12, 2005 | 10:08 PM
b18cEF9's Avatar
Default Re: this is getting old (redzcstandardhatch)
**** i got the same problem, sounds like it backfires, and feel like you slamm the brakes to the floor even tho your at WOT, pisses me off as well, bump for this
Old Sep 12, 2005 | 11:46 PM
h kid's Avatar
Default Re: this is getting old (b18cEF9)
well i had the same exact problem until about a week ago, it started of the same, in second gear I would go wot and at about 3 thousand rpms it would kinda backfire and jolt like when you axidently downshift when your way too high in gear to do it. the problem percisted until i stoped geting spark and i replaced my dizzy and problem solved now the thing runs smooth all the way up.
Old Sep 13, 2005 | 03:08 AM
lucidvtec's Avatar
bump for the dizzy.....how many miles on it....check that i bet it's ur problem...also check ur harness's in the bay....if a wire backs out it could cause this...i had that happen to me ...after cleanin my bay one time...took me a week to figure it out
Old Sep 13, 2005 | 07:45 AM
Team Evol Tyrone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raiden571 &raquo;</TD></TR><TR><TD CLASS="quote">ok. ive been talking with some people. is it possible that the dizzy is junk or maybe even the VSS?
anyway to check either of them?</TD></TR></TABLE>
Sup? Hey sometimes the ignitor inside the Dizzy goes bad mine did that and I replaced it and there it went working fine again. Try that before throwing away your Dizzy they starting to cost as much as a header these days.
Old Sep 13, 2005 | 01:58 PM
raiden571's Avatar
my car only has 73k on it and has only been turbod for about 2k, thast why i think it would be odd for it being the dizzy. im gonna try regapping the plugs first, simple. then ill move on to other stuff. bumpfor more info on this topic. gonna start the bs this weekend.
Old Sep 14, 2005 | 03:04 PM
raiden571's Avatar
i swapped over a different dizzy, didnt do a thing. regapped plugs, same problem. bump for some aid
BKJJ77
Mar 5, 2012 08:41 AM
akinas-crx
Engine Management and Tuning
Nov 13, 2011 06:52 PM
89b20crx
Mar 8, 2011 09:54 AM
ABTDer
Oct 30, 2003 06:30 PM
Krayzielix
Feb 2, 2003 04:12 PM
