Putting timing belt back on
Alright, this question pretty much goes for any DOHC motor, but I have a DOHC ZC. I stripped the timing belt tensor bolt, so I'm replacing that. My question is, as long as both cams are at TDC, and the crank is at TDC, I should be good right?
Yeah, I just remembered the distributer. Thats on the Camshafts though.
Any clarity into this issure would be appreciated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voodooboy520 »</TD></TR><TR><TD CLASS="quote">My question is, as long as both cams are at TDC, and the crank is at TDC, I should be good right</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">just put pins through the cams, and when you tension turn counterclockwise about 1/4 turn then tighten tensioner</TD></TR></TABLE>
thats what i did...
thats what i did...
