hows the integra feel with no power steering and how u go about removing it?
Old Sep 13, 2005 | 05:31 PM
importdays's Avatar
Default hows the integra feel with no power steering and how u go about removing it?
was thinkin about removing my p/s but i wanted to know what the people that already removed it think of it? do i need to change the rack n pinion cause i see oil lines running through it. and other advice would help.
Old Sep 13, 2005 | 05:34 PM
Drives EG's Avatar
Default Re: hows the integra feel with no power steering and how u go about removing it? (importdays)
i am also interested. since both my ef's didn't have power steering i would think it wouldn't be much different. i could very well be wrong though.
Old Sep 13, 2005 | 05:35 PM
97Alex's Avatar
lets start with WHY you want to remove it.
Why do you want to remove it?
And, yes there is a a M/S & a P/S rack n pinion are different
Old Sep 13, 2005 | 05:53 PM
txracer's Avatar
Default Re: (97Alex)
weight reduction, less drag on the motor wich gives more power, altought very very very little, in my eyes every little bit counts. altought i wouldnt remove mine, unless it ***** up
Old Sep 13, 2005 | 06:00 PM
importdays's Avatar
i dont see how ur post is helping me
Old Sep 13, 2005 | 06:06 PM
JDMoMo
Guest
Posts: n/a
Default Re: (importdays)
unless ur running track, don't take it off....weight reduction? how much are u going to loose man??? Just keep it and be happy that you have it cause it's a pain in the *** w/out it after a while.
Old Sep 13, 2005 | 06:14 PM
importdays's Avatar
Default Re: (JDMoMo)
is it that bad? ive had civic coupe with no power steering and it wasnt bad at all. is it much diff than the civic coupe with no power steering? i know the teg has a heavier front.
Old Sep 13, 2005 | 06:25 PM
acura_9485's Avatar
i wouldnt get rid of P/S...u said ur civic didnt have it, and it wasent bad, well ur civic was made to be without it...the integra was made for it....im thinking it would be a pain to be without. Especialy when u have a huge aftermarket performance to make ur car fast without having to sacrifice luxury....keep it, if u ask me
Old Sep 13, 2005 | 06:30 PM
Naruto's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importdays &raquo;</TD></TR><TR><TD CLASS="quote">i dont see how ur post is helping me</TD></TR></TABLE>
think about it for a second. No one knows really why you're removing it. Are you removing it for better performance on the track? Or are you removing it because you heard or someone told you they did it to their car and they felt as if there was a jump in performance? Depending on what you're going after, removing it can have negative side affects. Then again...it may not. You may like it and you may feel that the car drives better. Who knows.....
like jdmomo said...it IS a pain in the *** after a while. Especially when trying to park your car in a parking lot
Old Sep 13, 2005 | 06:48 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: (Naruto)
Pita in parking lots, but still possible.
plus it gives a much better feel on the road when you have stiff springs.
I've driven a car with suspension mods with no p/s, & then my car.
It doesn't feel as good with p/s when you have a stiff setup.
I'd take the p/s out if i wasn't on campus so much, or if i had the extra time.
Old Sep 13, 2005 | 06:49 PM
2ndgentegracer's Avatar
I just took the belt off, it's a bitch in parking lots but you get used to it. It feels so much better on the freeway now, I drove my friends LS thats still got P/S, it felt soo sloppy. Remove the belt and see how it feels.
Old Sep 13, 2005 | 06:52 PM
Naruto's Avatar
Default Re: (2ndgentegracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ndgentegracer &raquo;</TD></TR><TR><TD CLASS="quote">I just took the belt off, it's a bitch in parking lots but you get used to it. It feels so much better on the freeway now, I drove my friends LS thats still got P/S, it felt soo sloppy. Remove the belt and see how it feels.</TD></TR></TABLE>
ummm.....I can't think of why right now...but I do remember reading, and seeing why JUST removing the belt can be VERY bad for your car.......hopefully someone can either correct me...or post up why.
Old Sep 13, 2005 | 06:55 PM
Kendall's Avatar
My Integra felt great with no power steering, I loved every minute of it.
For reference sake, you can take the belt off to see how you like it and if you don't like it you can always put the belt back on.
Old Sep 13, 2005 | 06:58 PM
importdays's Avatar
good idea
Old Sep 13, 2005 | 07:02 PM
JDMoMo
Guest
Posts: n/a
Default Re: (FlatBlackTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatBlackTeg &raquo;</TD></TR><TR><TD CLASS="quote">Pita in parking lots, but still possible.
I'd take the p/s out if i wasn't on campus so much, or if i had the extra time.</TD></TR></TABLE>
Uhh, please do your studies on p/s because it has nothing to do with your highway driving. Did you know that p/s cuts off when you're driving above 15-20mph or so....not sure exact speed, but your p/s doesn't even work then so how do you know that w/out p/s your car is running better or smoother or whatever you think it is......
Old Sep 13, 2005 | 07:03 PM
Naruto's Avatar
Default Re: (Kendall)
Say Kendall.....isn't there more to it than just removing the belt though? Especially if you plan on leaving it that way? I swear I read about that somewhere.........like...if all you did was remove the belt, something not so good will be in store for you later on down the road....or something like that.
dammit....I can't find any info
Old Sep 13, 2005 | 07:09 PM
Tim2179's Avatar
eight equals equals equals D
Community Builder
Loved
Default Re:
here:
https://honda-tech.com/zerothread?id=462824
Not having P/S isn't bad. You get used to it fast. Yes, parallel parking becomes less enjoyable, but you'll be fine.
I went without P/S for years, but then finally decided I was tired of dealing with not having it. You get lazy when you get old.
Old Sep 13, 2005 | 07:11 PM
Naruto's Avatar
Default Re: Re: (Tim2179)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tim2179 &raquo;</TD></TR><TR><TD CLASS="quote"> You get lazy when you get old.</TD></TR></TABLE>
hahaha...ain't that the truth
Old Sep 13, 2005 | 07:24 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Naruto &raquo;</TD></TR><TR><TD CLASS="quote">Say Kendall.....isn't there more to it than just removing the belt though? Especially if you plan on leaving it that way? I swear I read about that somewhere.........like...if all you did was remove the belt, something not so good will be in store for you later on down the road....or something like that.</TD></TR></TABLE>
To get any kind of weight benefit you need to remove the pump and the lines, but you will reduce the drag on the motor with just the belt removed. The issue a lot of people have is when you remove the lines, dirt can get in the rack, I've never had a problem, but it doesn't eliminate the potential. I say if you **** up the rack, then just go get another one.
Old Sep 13, 2005 | 07:32 PM
Naruto's Avatar
yea...after searching on the good ol search monster here... I found this thread where pubestripe said:
link to thread: https://honda-tech.com/zerothread?id=1329981
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pubestripe &raquo;</TD></TR><TR><TD CLASS="quote">
even if you correctly remove the lines, it still is not going to be strong enough to support non power steering. you need to get a rack out of an eg that did not have ps, that is if u have a dc teg. if u have a da teg u need to get a rack out of an ef civic. these power steering racks were made for power steering, so overtime they will break.
not too sure if he's 100% correct.
then I found a wonderful article for the originator of this post Its a damned good write up and I seriously recommend to at least take a look at it
https://honda-tech.com/zerothread?id=184202
Old Sep 13, 2005 | 07:38 PM
.one lane's Avatar
.likes trains
lol! whoa i posted in this thread " https://honda-tech.com/zerothread?id=1329981 "
if you're lazy to go out and buy all the parts, padawan has a kit that has all the parts.
https://honda-tech.com/zero...age=1
Old Sep 13, 2005 | 07:40 PM
Naruto's Avatar
Default Re: (Mr. One Lane)
hahaha....that you did! Same link I posted too about the write up
searching goes a looooong way
Old Sep 13, 2005 | 07:56 PM
ONISHIMA's Avatar
I DONT HAVE p/s in my integra it came with it but the person who had the car before me took it off for the swap.&he took out the a/c too (i'll put on nxt year not soo hot in tulsa ,oklahoma i dealt without it for a year now so its coo) and the power steering..and to be honest im use to it b/c the teg was my first car so i adjusted to the no power steering...but when i drive my moms G20 its feels really weird cause im not use to it..but over all having no p/s isnt bad thats just my two cents , but not having a/c sucs ! lol
Old Sep 13, 2005 | 11:29 PM
White GSR '01's Avatar
Default Re: (ONISHIMA)
Let's not worry about why he wants to do it. Just tell him what he needs to know. If you just take the belt off and leave the p/s rack on there, it will be a bitch to drive. I drove my friends WRX after his p/s failed and it is hard as **** to turn no matter how fast you are going. You should be able to use the same rack as a m/s honda civic. That will make it easier to deal with than just taking the belt off.
Honda Tuning magazine put out an article on taking the p/s off of a Type R.
Pulling off the belt frees up some horsepower by getting rid of the parasitic losses inherent in anything belt driven. It also sheds some weight.
BUT!!!!!!, By just pulling out the pump, belt, and lines leaves the rack unlubricated and vulnerable to premature wear and locking up.
The article is called "Old Dog, New Tricks" in the August issue with the dark blue prelude on the front. If you don't get the mag, go to http://www.hondatuningmagazine.com and look it up
Old Sep 14, 2005 | 01:27 AM
Naruto's Avatar
Default Re: (White GSR '01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White GSR ’01 &raquo;</TD></TR><TR><TD CLASS="quote">
The article is called "Old Dog, New Tricks" in the August issue with the dark blue prelude on the front. If you don't get the mag, go to http://www.hondatuningmagazine.com and look it up </TD></TR></TABLE>
THANK YOU!!!!! I remembered something detrimental would or could happen if all one did was JUST remove the belt and not take into consideration that there's other things needed to be done. I just couldn't remember it
