Transmission help
I have a CTR transmission that was on a car that was wrecked. My friend said that the gear selector is bent. From messing around with it all I can tell is that it won't go into 1st or 5th.
I was wondering what I could look for which would indicate whether the gears are going to grind.
Here are some pictures. I don't know EXACTLY what's wrong with it, so if you can see anything in the pics let me know. TIA
Modified by Kouki-EK9 at 2:57 PM 9/13/2005
Modified by Kouki-EK9 at 8:38 PM 9/15/2005
with the outer case 1/2 off, they will wobble a fair amount.........
the shift shaft might be bent, but that would lock you out of the lower gears, 2-4-R.........
cxSHOE
51
Nov 24, 2003 05:43 PM
